lean burn ignition system #2090443
06/12/16 02:41 AM
06/12/16 02:41 AM
St.Louis ,Mo.
72sat Offline OP
72sat  Offline OP
St.Louis ,Mo.
I'm thinking about making a sleeper out of my 78 lebaron. should I keep the lean burn, or ditch it. how tunable is it
Re: lean burn ignition system [Re: 72sat] #2090446
06/12/16 02:42 AM
06/12/16 02:42 AM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
DITCH IT.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: lean burn ignition system [Re: DARTH V8Я] #2090452
06/12/16 02:59 AM
06/12/16 02:59 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
It is not real tunable. It had some reliability issues....okay, a lot of reliability issues. The concept of having electronics on top of an engine in all the heat does not make for a real reliable set up. It was, IMHO, a decent idea but poorly executed.
Most have yanked the lean burn and gone to a regular vacuum/mechanical advance system that does tune a lot easier.
Craig
Re: lean burn ignition system [Re: 72sat] #2090636
06/12/16 02:08 PM
06/12/16 02:08 PM
Alberta
rustbuckett68 Offline
Alberta
Mopar Action article "trash that lean burn". Did that to an 86 Chrysler, simple and effective.
Re: lean burn ignition system [Re: 72sat] #2090642
06/12/16 02:14 PM
06/12/16 02:14 PM
Milwaukee, WI
moparjimbo Offline
moparjimbo  Offline
Milwaukee, WI
Do not even think about keeping it.... Very simple to convert to a regular electronic ignition and regular carb of various sorts.
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire
1973 Challenger - 572 Indy Hemi 860HP
1975 Trailduster Convertible, 440
1967 Plymouth Fury Police Pursuit 2DR 505 Stroker
2004 Neon SRT4 modded
www.milwaukeemopar.com
Re: lean burn ignition system [Re: 72sat] #2091155
06/13/16 12:20 PM
06/13/16 12:20 PM
Chicago suburbs
dartgame Offline
dartgame  Offline
Chicago suburbs
Toss it. Replace with a standard carb and electronic ignition. World of difference. Wiring will be a little work, a service manual for your car and a non lean burn wiring diagram will help immensely.
Re: lean burn ignition system [Re: 72sat] #2093890
06/18/16 11:29 AM
06/18/16 11:29 AM
5thAve Offline
5thAve  Offline
78 should already have a ballast resistor for that generation computer so some of the wiring is already done for you. You just need to do the rest of it and the the distributor and different carberator.
Re: lean burn ignition system [Re: 72sat] #2093896
06/18/16 11:42 AM
06/18/16 11:42 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Perhaps one of Chrysler's worst nightmares, trash it...I've converted a few, install a factory or aftermarket manifold/carb system of your choice, use a Chrysler single point vac adv. dist. install a Pertronix conversion kit along with the proper coil, do have a factory service manual so you can you can eliminate the computer, half the harness nightmare, along with the ballast resistor(s)correctly for a trouble free system that's reliable
Re: lean burn ignition system [Re: 72sat] #2094700
06/20/16 12:04 AM
06/20/16 12:04 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Had a 5th Ave lone time ago. Typical totally underpowered 318. One time it failed to start, no spark.
In order to get it home I brought a spare points distributor and a jumper wire. Not only was I happy that we did not have to hire a tow truck but this 5th that would previously barely climb a speed bump was now spinning the rear tire. So it could now lay rubber and it felt like it picked up 50hp.
We then converted to the MP elec ign w the orange box. To this day it makes me wonder why anyone would put up with the lack of power the Lean Burn cars had.
Re: lean burn ignition system [Re: Magnum] #2094860
06/20/16 10:42 AM
06/20/16 10:42 AM
moparx Offline
moparx  Offline
back when lean burn was new, i owned a junk yard [which was the correct term for a place that bought and sold junk cars. i know, the term is hard to believe !]. we sold all the points and electronic distributors plus wiring and matching coils and carbs we could come up with. this was to individuals, repair shops, and dealers alike. nobody could get those systems to run correctly. made a pretty good buck on just those conversions when those conversions were not really a "kit" item.
beer
