Engine dies when I stop turning the key #2090311
06/11/16 09:33 PM
06/11/16 09:33 PM
Louisiana
duckblind Offline OP
Louisiana
I have a 68 charger. It fires right up and will stay running as long as I am still turning the key. As soon as I release the key the car dies. What could cause this? Thanks
Re: Engine dies when I stop turning the key [Re: duckblind] #2090315
06/11/16 09:48 PM
06/11/16 09:48 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Sounds like classic ballast resistor gone bad.
Re: Engine dies when I stop turning the key [Re: duckblind] #2090320
06/11/16 10:07 PM
06/11/16 10:07 PM
Louisiana
Louisiana
Ok. That's a cheap enough part. I will swap it out and see what happens.
Re: Engine dies when I stop turning the key [Re: duckblind] #2090333
06/11/16 10:45 PM
06/11/16 10:45 PM
yes if you have another one sub it in otherwise before purchasing one just jump across the the ballast terminal with a piece of wire & see if it will stay running. if it now stays running shut it off immediately & replace the ballast. If it still don't stay running holler back & we'll continue on
Re: Engine dies when I stop turning the key [Re: duckblind] #2090346
06/11/16 11:04 PM
06/11/16 11:04 PM
Louisiana
Louisiana
I replaced it and it still don't stay running. I have a mallory unilite distributor with an inline filter. I wonder if the filter went bad? I also fairly recently soldered some of the connections together between the distributor and resistor because the plugs seemed lose. However I ran the car several times since doing that. I jumpered around those connections just now with some of those electrical connectors that just stab into the wires but the car still did not stay running.
Re: Engine dies when I stop turning the key [Re: duckblind] #2090366
06/11/16 11:59 PM
06/11/16 11:59 PM
S.W. PA
6PACMAC Offline
6PACMAC  Offline
S.W. PA
Maybe your ignition switch. The "run" position sounds like it is bad. Or maybe the wire or connector at the run position is having problems. When you turn the key to crank, voltage is supplied to the starter and the ingnition. When you release the key, it goes to the run position, just supplying voltage to the ignition. Good luck
Re: Engine dies when I stop turning the key [Re: duckblind] #2090456
06/12/16 03:08 AM
06/12/16 03:08 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
If the ballast is okay, it is your switch or bulkhead connector. The Ignition 1 12V on the dark blue wire is gone. Easy to check with a meter. Ignition 2 on the brown wire is present, that is why it starts.
Craig
Re: Engine dies when I stop turning the key [Re: duckblind] #2091066
06/13/16 08:48 AM
06/13/16 08:48 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Check wiring at connector that ties ignition switch to dash harness. Commonly overlooked issue, along with bulkhead connector.
