appearance of bulkhead at firewall ? #208988
01/30/09 11:08 PM
01/30/09 11:08 PM
KY
juicedcuda Offline OP
KY
What are some ways of cleaning up the appearance of the bulkhead at the firewall? Custom covers, etc?
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: appearance of bulkhead at firewall ? [Re: juicedcuda] #208989
01/31/09 12:14 AM
01/31/09 12:14 AM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
ive never seen covers for the bulkhead con. most custom guys relocate it to the inside to smooth out the fire wall.
Re: appearance of bulkhead at firewall ? [Re: moparsquid] #208990
01/31/09 10:08 AM
01/31/09 10:08 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
I welded patches into the holes I am not going to use and cleaned up the whole area. When I install new stuff (A/C, wire harness, etc.) I'll cut new holes in the best locations.
Driving modern convenience in classic beauty
Re: appearance of bulkhead at firewall ? [Re: Darius] #208991
01/31/09 10:10 AM
01/31/09 10:10 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
2nd pic, I have it primed now, just no pic yet. It looks real clean.
This is during filling and sanding after patching
Re: appearance of bulkhead at firewall ? [Re: Darius] #208992
01/31/09 10:28 AM
01/31/09 10:28 AM
KY
KY
the bulkhead is the back side of the fuse panel correct? I wanted to avoid relocating the fuseblock.
Re: appearance of bulkhead at firewall ? [Re: juicedcuda] #208993
01/31/09 11:06 AM
01/31/09 11:06 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Nope. The bulkhead has female terminals on the firewall from the passenger compartment and the engine side has harnesses with Male sides. Your fuseblock depends on the body. A-Body is on the left side of the dash by the kick panel, B body is usually in the glovebox. E-Body...I havent a clue
I have seen custom aluminum covers for those bulkheads and all the wires coming out of it are inserted at 90 degrees. Bit much.... A nice clean neatly wrapped harness looks just fine. Relocating the whole thing to the inside might look nice but in the long run, crawling underneath to disconnect something will be a PITA
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: appearance of bulkhead at firewall ? [Re: Pyper70] #208994
01/31/09 01:30 PM
01/31/09 01:30 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Mid 80's and up Dodge trucks and vans had a rubber boot like cover that covered the wires at the bulkhead connector on the engine side.
Nautilus Racing-
Re: appearance of bulkhead at firewall ? [Re: Pyper70] #208995
02/01/09 03:23 AM
02/01/09 03:23 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
on 71-74 B bodies same as E bodies fuseblock is on back of bulkhead, hold by clips provided on bulkhead.
Re: appearance of bulkhead at firewall ? [Re: juicedcuda] #208996
02/01/09 03:22 PM
02/01/09 03:22 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Pull the bulkhead connection inside, as on '76-'78 F-bodies:
