436" Arrington Head Dyno #'s #208913
01/30/09 08:31 PM
01/30/09 08:31 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
Smooth dyno session today.....
4.10" bore non Siamese R3
4.125" Stroke offset ground K1 crank
6" CompStar 2.0" rods
Custom Diamonds -28CC dish, 11.1:1 compression
Moroso 8 Qt pan
SDSS Solid roller 272/276 @ .050" .729"/.729" 108 LSA+4
1.65:1 Jesels
Arrington heads, 2.15"/1.60" Ferrea's, ISKY 9985 tool rooms, Comp tool steel retainers. Flow ~360/260 @ .700"
Manton 3/8" .145" wall P rods
Arrington single 4 cast manifold converted to 4500 flange
Ran Quickfuel 1050 & a Pro Systems 1050 both virtually identical power.
Liked 33 degrees of timing (heads angle milled to 13 degree at some point in previous life)
Built as a pump gas street motor so no compression or wild cam. Motor turns over with 36.9 ft lbs of TQ ready to run with plugs in it, lashed etc.... Made real good TQ helped by smallish intake. I did'nt go wild on it to keep costs down. I was surprised by how good the TQ was, we pulled it down to 4100 late in day & it was making 540 @ 4100.... Made best of 610 TQ.
We ran it with my 1 7/8" into 2" Dyno headers with 3.5" collectors, & then put on a set of Box stock TTI W2 1 7/8" Headers with 3" collectors to see power difference.... here are the results. First #'s were with the stepped big tubes...
Re: 436" Arrington Head Dyno #'s [Re: RyanJ] #208914
01/30/09 08:34 PM
01/30/09 08:34 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
Box Stock TTI 1 7/8" W2 A/B/E Body headers:
Re: 436" Arrington Head Dyno #'s [Re: RyanJ] #208915
01/30/09 10:30 PM
01/30/09 10:30 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Ryan,
Thanks for posting this...it goes to illustrating my point made on the header thread how a too small collector will (for want of a better word) "FORCE" the motor's torque to Peak at too low an RPM which acts like a cork onthe rest of the higher RPM Horsepower curve. Looks like the 3" collector peaked at 5300 where the 3 1/2 peaked up around 5900....look how much power that is.....I know the bigger ones are stepped but I'll bet 80% of the power gain was from the larger collector letting the motor keep "feeding".
WIZE
In Car:
Re: 436" Arrington Head Dyno #'s [Re: Streetwize] #208916
01/30/09 10:36 PM
01/30/09 10:36 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
Thanks Ryan I always look forward to reading your dyno posts. I really like how you don't try to hide anything about the motors.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: 436" Arrington Head Dyno #'s [Re: Jacob Pitt] #208917
01/30/09 11:15 PM
01/30/09 11:15 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Man someone is busy
I can hardly keep up with all these motors you have on the pump
things are booming in state college
Re: 436" Arrington Head Dyno #'s [Re: 340RICK] #208918
01/31/09 03:27 AM
01/31/09 03:27 AM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
So- a hypothetical question... what other head(s)would give the same results on that same shortblock without being totally obscure or WAAAYY overpriced(porting price being factored in)?- and still maintaining the streetable factor. What would be your first choice? Indy 245, w9, w7?
Thanks for posting all these dyno results- they are appreciated
Re: 436" Arrington Head Dyno #'s [Re: 72demon416] #208919
01/31/09 11:58 AM
01/31/09 11:58 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
You pretty much listed them, I'd say Indy 245 on a 59° block, and w9 on a 48° block.
Indy
https://board.moparts.org/ubbthreads/show...rue#Post4642330
W9
https://board.moparts.org/ubbthreads/show...rue#Post4230722
Re: 436" Arrington Head Dyno #'s [Re: Streetwize] #208920
01/31/09 12:00 PM
01/31/09 12:00 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Ryan,
Hard to say without knowing the primary lengths, I'd think the primary's dictate the RPM more then the collector size... But if they're close to the same, then you're definately right.
Re: 436" Arrington Head Dyno #'s [Re: dizuster] #208921
02/01/09 12:22 PM
02/01/09 12:22 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
Put it in the car yesterday (with much help from mrsmallblock for running a 727 neutral bal 6 bolt SFI Flex plate up to Port Royal for us, THANKS Howard) Neede to get motor in yesterday so can get driveshaft made this week & order the radiator, & start plumbing fuel system & wiring etc.
Sorry for the poor pic quality I just realized this AM my camera accidentally was set on Blur Reduction last night when I took these. I'll get some better ones next weekend when we work on it again. Hopefully should be done here in month or two.
It's a '72 Challenger, the guy doing all the body/paint/fab work is the guy who is going to do my SuperBee body/paint as soon as this one is done.
Started out as a very rusted out shell out of Georgia... all new floorpans, 1/4's, much of firewall rebuilt new inner fenders, fixed several holes in roof....
Back halfed it, ladder bars, QA1's, Mini tubs, cage etc. Ron Francis wiring, 8" ATI verter, custom 727 by Scotts Transmission in Lebanon, PA. 14.5" Quick time Pro's on Holeshot Penatstars, AlterKtion...
I think I have him talked into doing a WS fiberglass oversize 6 pack lift off hood blacked out. Gonna have Black '71 Challenger RT stripes when done, it just got out of paint booth a few weeks ago. Going to run Friday night Street racing deal at Beaver Springs this year with it, wants to run in the quick 8 deal.
Anyhow, here's couple bad pics.....
Re: 436" Arrington Head Dyno #'s [Re: RyanJ] #208922
02/01/09 12:23 PM
02/01/09 12:23 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
X
Re: 436" Arrington Head Dyno #'s [Re: RyanJ] #208923
02/01/09 12:24 PM
02/01/09 12:24 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
Z
Re: 436" Arrington Head Dyno #'s [Re: RyanJ] #208924
02/01/09 12:25 PM
02/01/09 12:25 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
W
Re: 436" Arrington Head Dyno #'s [Re: RyanJ] #208925
02/01/09 12:26 PM
02/01/09 12:26 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
221
Re: 436" Arrington Head Dyno #'s [Re: RyanJ] #208926
02/01/09 12:27 PM
02/01/09 12:27 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
222
Re: 436" Arrington Head Dyno #'s [Re: RyanJ] #208927
02/01/09 12:28 PM
02/01/09 12:28 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
223
Re: 436" Arrington Head Dyno #'s [Re: RyanJ] #208928
02/01/09 12:29 PM
02/01/09 12:29 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Its even your favorite color Ryan
nice cant wait to see it finished
ist this the dude that bought my old headers and exhaust
Re: 436" Arrington Head Dyno #'s [Re: 340RICK] #208929
02/01/09 12:33 PM
02/01/09 12:33 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
It's actually some type of PPG bright red. He called it "really red" I don't know if that's the real name or not, but it's a bright vibrant red. (My favorite is Orange LOL)
I gave Buck (the painter) some of my flake yesterday for him to test shoot, he has'nt shot flake in years. Just wants to make sure he can get it to lay down good.
Yes this was guy who got your Headers but they did'nt work out, these are newer style Arrington heads, I actually ended up having to get a set of W2 TTI's & change bolt pattern on heads to that. (someone had changed it from W2 to W7 pattern.... what a mess, so I had to close off W7 pattern & redrill W2....)
Re: 436" Arrington Head Dyno #'s [Re: RyanJ] #208930
02/01/09 03:34 PM
02/01/09 03:34 PM
La Vernia, Texas
Pat7272 Offline
Pat7272  Offline
La Vernia, Texas
Wow that looks great!
Re: 436" Arrington Head Dyno #'s [Re: RyanJ] #208931
02/01/09 04:36 PM
02/01/09 04:36 PM
Uppsala, Sweden
Satanized_68 Offline
Uppsala, Sweden
First of all, very nice numbers! No need for big blocks anymore
I was wondering over the oil adapter, it looks really good using that AN -12 in the front of the engine,
I'm thinking of doing something similar on my engine.
Is that CV Products adapter? Do you have the part #'s for what is needed? What do you use where the
oil filter was originally placed?
Thanks, and sorry for hijacking the thread
Getting closer... <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: 436" Arrington Head Dyno #'s [Re: Satanized_68] #208932
02/01/09 04:53 PM
02/01/09 04:53 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Great numbers on those dyno runs. That is one nice car getting put together there.
