Re: Best Water Pump
[Re: jeebis44]
#2089129
06/09/16 03:39 PM
06/09/16 03:39 PM
RapidRobert
get a parts house 8 blader (non AC) & you will be fine. cut an anticav plate on it if desired. I cut one out of the side of an old washing machine. cut the OD slightly less than the OD of the blade tips so you can tack several of em and drill a center hole & tack it there too. concentrate on a good 3 row and an MP clutch fan with 7 blades properly postitioned into a schroud with a 180 stat and proper pulley ratio. #1 need good airflow
Re: Best Water Pump
[Re: Neil]
#2089594
06/10/16 12:22 PM
06/10/16 12:22 PM
RapidRobert
agreed, the aftermarket pumps flow more IF NEEDED, & are pricey which I wouldn't think would be needed in this app. find a good radiator! I'd get a Champion 3 row from the guy on here who sells (& guarantees em). my Champion 2 row (eBay) was 189 to my door
Re: Best Water Pump
[Re: jeebis44]
#2089764
06/10/16 07:01 PM
06/10/16 07:01 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I've had very good results with GNB pumps.
