Re: 360 backfire
[Re: sportfury70]
#2088642
06/08/16 10:17 PM
06/08/16 10:17 PM
RapidRobert
I would (1) hook the can to ported (2) check rotor phasing (3) confirm the can don't have a leak, somewhat rare but I would check it
Re: 360 backfire
[Re: mopartruckguy]
#2088655
06/08/16 10:34 PM
06/08/16 10:34 PM
RapidRobert
when the coil fires you need the rotor blade tip to be fairly close to the cap terminal cuz if that distance is too great the spark cannot jump it repeatedly & it will act up which is seen as a misfire and only the can alters RP. the can is causing the problem (one way or the other) so with it on manifold it may cause a problem at idle (just too much timing) but I was thinking it was above idle. the can may or may not be shifting RP to where there is a problem. rarer is a leak in the can diaphram causing a lean misfire. As Stump said get your timing to a reasonable baseline & I would highly suggest plugging the can into ported & see what develops & holler back. EDIT Are you saying you dont have a dialback? (1) degree is 0.0632683" around the dampener circumference and you can cut/measure a strip of newspaper with your calipers & make black ink marks on it to use it as a ruler to make new white paint marks on your dampener, IE 17.5/20/22.5/25/27.5/30/32.5/35 degrees. for example 17.5 deg is 1.107" (CW from the OE TDC slit) MORE EDIT I reread & it sputters on ported or manifold. I'd cap the can & set initial at 15 for a start then plug the can into ported (I'm assuming your idle speed is low enough so there is no vac at your idle speed at the ported nipple) & try it
Re: 360 backfire
[Re: stumpy]
#2088924
06/09/16 11:01 AM
06/09/16 11:01 AM
Posts: 19,408 north of coder
moparx
don't forget, if you increase the initial a bunch, make sure you remove some from the total so you end up with somewhere around 34-38* at WOT with the can disconnected. as to how fast the total comes on, that is determined by the weight springs. you will need to experiment with these to find out what works best for you. when you accomplish that, then start playing around with the vacuum advance. that only comes into play at a low/no load condition. you should be able to use around 40-50* or so total timing on the vacuum advance at a steady, NO LOAD cruise. EACH engine/vehicle/fuel combo can and will be different, so experimentation is the ONLY way to find the sweet spot for your combination. different cans are available, and don't forget that the diaphragm inside the can is able to be adjusted as well. ebooger did a comprehensive article on how to adjust timing for mopar action several years ago. it's well worth reading and implementing. and when the vacuum advance is dialed in correctly, you will benefit from increased gas mileage.
