Oil slinger 383 #2088088
06/08/16 12:19 AM
06/08/16 12:19 AM
central new york
pettyblue440 Offline OP
central new york
Do I need it?
Will Napa have it?
Thnx jon
Re: Oil slinger 383 [Re: pettyblue440] #2088103
06/08/16 12:47 AM
06/08/16 12:47 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
not really necessary.
Re: Oil slinger 383 [Re: stumpy] #2088107
06/08/16 12:53 AM
06/08/16 12:53 AM
there was a debate awhile back as to whether it is an "oil slinger" (what everybody refers to it as) or if it is to help protect the front of the eng from oil leaks out the front which would inundate Ma with dealer comebacks. seal quality is light years better than way back so what Stump said, you'll be fine (assuming correct seal installation) but if you have one I would use it (& NAPA wont have it). I can get one to your front door for a ten dollar bill. that way you know you are "correct". You'll sleep better at night (as will I!).
Re: Oil slinger 383 [Re: pettyblue440] #2088164
06/08/16 03:34 AM
06/08/16 03:34 AM
Cab_Burge Online work
Cab_Burge  Online Work
I use them on all my motor builds, street, street and strip or race only thumbs I buy them a dozen at at time from 440 Source scope
Re: Oil slinger 383 [Re: pettyblue440] #2088262
06/08/16 11:49 AM
06/08/16 11:49 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I doubt Napa will have it, shouldn't be hard to find them though , I probably have an extra one .
Re: Oil slinger 383 [Re: pettyblue440] #2088269
06/08/16 11:57 AM
06/08/16 11:57 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ive had factory with and without.Seems the later engines there were less with them.I think ever early one I tore down did have one.Not really necessary though.Rocky
Chrysler Firepower
Re: Oil slinger 383 [Re: pettyblue440] #2088286
06/08/16 12:23 PM
06/08/16 12:23 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
And if you put one on there, DO NOT put it on backwards!
Re: Oil slinger 383 [Re: buildanother] #2088361
06/08/16 02:17 PM
06/08/16 02:17 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
The way I look at it is its there for a reason. We can speculate all day long but we don't know for sure why it's there. With the amount of R&D that they put into their product back in the day I would say they saw a benefit to having that part along for the ride.
Abe Lincoln
Re: Oil slinger 383 [Re: pettyblue440] #2088386
06/08/16 02:52 PM
06/08/16 02:52 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
It is for blocking the oil from the seal. Don't believe it? Look at the rear main seal area on a crankshaft. See anything odd? There is a built in ring around the crank to block the oil going from the bearing to the seal area.
have any other reason for that being there?
Re: Oil slinger 383 [Re: RapidRobert] #2088393
06/08/16 03:19 PM
06/08/16 03:19 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
That's what the factory refers to it too.
Re: Oil slinger 383 [Re: NANKET] #2088398
06/08/16 03:28 PM
06/08/16 03:28 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
iagree
slings the oil away from the seal. Same purpose for the front slinger. Slings oil on the timing chain as well.
Abe Lincoln
Re: Oil slinger 383 [Re: dart4forte] #2088418
06/08/16 03:45 PM
06/08/16 03:45 PM
dogdays Offline
dogdays  Offline
The active word is "slings". It doesn't just block the oil from running that way, like a dam, but as the crankshaft turns,the slinger helps any oil that comes in contact with it to fly away.
I cannot understand why this is so hard to grasp. Oil slingers are used all the time in industrial equipment. It is not a Mopar-only concept.
The reason one can leave it off is that the lip seals are pretty good these days and can handle having some oil on them.
The front oil control device that amuses me is the stationary sleeve fitted around a sort of screw thread rotating with the crankshaft. Rotation of the crank turns the thread that pushes oil back into the engine. It's not really a seal, but it does keep leakage to a minimum. It can also propel debris into the engine.
R.
Re: Oil slinger 383 [Re: pettyblue440] #2088455
06/08/16 04:51 PM
06/08/16 04:51 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Originally Posted By pettyblue440
Do I need it?
Will Napa have it?
Thnx jon
Yes, it is there for a reason
No, they don't have everything
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Oil slinger 383 [Re: Polarapete] #2088525
06/08/16 07:15 PM
06/08/16 07:15 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Do I need it?
Will Napa have it?
Thnx jon
Mancini or 440Source
Abe Lincoln
Re: Oil slinger 383 [Re: dart4forte] #2088556
06/08/16 08:13 PM
06/08/16 08:13 PM
Idaho
LaRoy Engines Offline
Idaho
I remove them from all my builds. Sometimes the new seals in the timing cover actually press against the slinger and push the clearance out of the crank thrust surface on one side. We always check the crank thrust on every engine that someone else builds before and after it bolts on the dyno. Before bolting them up we have found thrust forward and the crank springs back when releasing the pressure. Each time it has been the slinger pushing against the extended seal acting like a spring shoving the crank to the back of the engine. We haven't had any leaks from tossing the slinger into the trash.
Re: Oil slinger 383 [Re: LaRoy Engines] #2088601
06/08/16 09:28 PM
06/08/16 09:28 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Evidently some of the new seals are different enough to make the slinger unnecessary. Good to know
2008 Honda Element
Re: Oil slinger 383 [Re: LaRoy Engines] #2088680
06/08/16 11:09 PM
06/08/16 11:09 PM
the plot thickens! I am for sure gonna check that next time. thanks for the heads up!
