Re: Oil slinger 383
[Re: stumpy]
#2088107
06/08/16 12:53 AM
06/08/16 12:53 AM
RapidRobert
there was a debate awhile back as to whether it is an "oil slinger" (what everybody refers to it as) or if it is to help protect the front of the eng from oil leaks out the front which would inundate Ma with dealer comebacks. seal quality is light years better than way back so what Stump said, you'll be fine (assuming correct seal installation) but if you have one I would use it (& NAPA wont have it). I can get one to your front door for a ten dollar bill. that way you know you are "correct". You'll sleep better at night (as will I!).
Re: Oil slinger 383
[Re: pettyblue440]
#2088262
06/08/16 11:49 AM
06/08/16 11:49 AM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
I doubt Napa will have it, shouldn't be hard to find them though , I probably have an extra one .
Re: Oil slinger 383
[Re: pettyblue440]
#2088269
06/08/16 11:57 AM
06/08/16 11:57 AM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
Ive had factory with and without.Seems the later engines there were less with them.I think ever early one I tore down did have one.Not really necessary though.Rocky
Chrysler Firepower
Re: Oil slinger 383
[Re: buildanother]
#2088361
06/08/16 02:17 PM
06/08/16 02:17 PM
Posts: 16,153 Mesa, Arizona
dart4forte
Mesa, Arizona
The way I look at it is its there for a reason. We can speculate all day long but we don't know for sure why it's there. With the amount of R&D that they put into their product back in the day I would say they saw a benefit to having that part along for the ride.
Abe Lincoln
Re: Oil slinger 383
[Re: RapidRobert]
#2088393
06/08/16 03:19 PM
06/08/16 03:19 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
there was a debate awhile back as to whether it is an "oil slinger" (what everybody refers to it as) That's what the factory refers to it too.
Re: Oil slinger 383
[Re: NANKET]
#2088398
06/08/16 03:28 PM
06/08/16 03:28 PM
dart4forte
Mesa, Arizona
It is for blocking the oil from the seal. Don't believe it? Look at the rear main seal area on a crankshaft. See anything odd? There is a built in ring around the crank to block the oil going from the bearing to the seal area.
have any other reason for that being there? slings the oil away from the seal. Same purpose for the front slinger. Slings oil on the timing chain as well.
Abe Lincoln
Re: Oil slinger 383
[Re: pettyblue440]
#2088455
06/08/16 04:51 PM
06/08/16 04:51 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Do I need it? Will Napa have it?
Thnx jon Yes, it is there for a reason No, they don't have everything
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
Re: Oil slinger 383
[Re: Polarapete]
#2088525
06/08/16 07:15 PM
06/08/16 07:15 PM
dart4forte
Mesa, Arizona
Thnx jon Yes, it is there for a reason No, they don't have everything Mancini or 440Source
Abe Lincoln
Re: Oil slinger 383
[Re: LaRoy Engines]
#2088601
06/08/16 09:28 PM
06/08/16 09:28 PM
Polarapete
Graham, WA
I remove them from all my builds. Sometimes the new seals in the timing cover actually press against the slinger and push the clearance out of the crank thrust surface on one side. We always check the crank thrust on every engine that someone else builds before and after it bolts on the dyno. Before bolting them up we have found thrust forward and the crank springs back when releasing the pressure. Each time it has been the slinger pushing against the extended seal acting like a spring shoving the crank to the back of the engine. We haven't had any leaks from tossing the slinger into the trash. Evidently some of the new seals are different enough to make the slinger unnecessary. Good to know
Re: Oil slinger 383
[Re: LaRoy Engines]
#2088680
06/08/16 11:09 PM
06/08/16 11:09 PM
RapidRobert
I remove them from all my builds. Sometimes the new seals in the timing cover actually press against the slinger and push the clearance out of the crank thrust surface on one side. We always check the crank thrust on every engine that someone else builds before and after it bolts on the dyno. Before bolting them up we have found thrust forward and the crank springs back when releasing the pressure. Each time it has been the slinger pushing against the extended seal acting like a spring shoving the crank to the back of the engine. We haven't had any leaks from tossing the slinger into the trash. the plot thickens! I am for sure gonna check that next time. thanks for the heads up!
