Need Some Math/Geometry Help
#2086496
06/05/16 05:09 PM
06/05/16 05:09 PM
Posts: 25,885 Rio Linda, CA
John_Kunkel
Rio Linda, CA
My '56 Plaza has 2" dropped spindles and it bottoms out everywhere; I'd like to install stock spindles but want to know how it will affect the front bumper height.
Using the dimensions in the pic below, how much will the bumper rise if stock spindles (move spindle shaft down) are installed? Are the supplied dimensions enough to compute that?
Re: Need Some Math/Geometry Help
[Re: John_Kunkel]
#2086535
06/05/16 06:10 PM
06/05/16 06:10 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
African or European swallow?
Assuming front is lower than rear, then less than 2" not more.
[Re: John_Kunkel]
#2086537
06/05/16 06:13 PM
06/05/16 06:13 PM
Posts: 529 SW CO
HemiSportFury
SW CO
(2/115)*23 added to 2 or 2.4 as stated above.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60 '57 Belvedere 2dr sedan, current project in process '19 Cherokee Trail Hawk Elite '03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
[Re: crackedback]
#2086542
06/05/16 06:19 PM
06/05/16 06:19 PM
Posts: 892 MA
steve70
MA
Roughly a bit more than 2" 2.4" roughly is a quick and dirty guess. That is correct. (2.3995)
1970 Challenger T/A 4 speed
[Re: BigBlockMopar]
#2086647
06/05/16 09:26 PM
06/05/16 09:26 PM
RapidRobert
What BBM said, I'm wondering if stiffer tbars would take care of it along with possibly trimming some of the height of the black rubber bumpers. it'd save you the cost of the new spindles (you may have kept em tho) & not sure if realigning is required
[Re: BigBlockMopar]
#2086673
06/05/16 09:52 PM
06/05/16 09:52 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I think what you really want (if you still like the current lowered look) is better springs and shocks.
I have a friend that is building a '56 Plymouth street rod and is planning to use a Volare clip. He has the original springs & spindles (he never throws anything away) and I could check with him, but I really think that BBM has the right answer for you. And I think there are better solutions than a Volare clip for my friend, too. But, what do I know?
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: RapidRobert]
#2086813
06/06/16 02:18 AM
06/06/16 02:18 AM
John_Kunkel
Rio Linda, CA
What BBM said, I'm wondering if stiffer tbars would take care of it have kept em tho) & not sure if realigning is required No T-bars on a '56, originally coils; and besides, it has a Dakota front clip. 2.4" it is, thanks for the help guys.
[Re: moparx]
#2087082
06/06/16 03:19 PM
06/06/16 03:19 PM
John_Kunkel
Rio Linda, CA
The lower control arms and crossmember are the usual points of contact and occasionally the pan on speed bumps. Dropped spindles are nice for keeping the front end geometry intact but, unlike shorter springs, they also drop the lower control arm lower than the rim. I raised the bumper 2.5" with a floor jack and it still has a slight nose-down attitude.
[Re: BigBlockMopar]
#2087205
06/06/16 06:19 PM
06/06/16 06:19 PM
John_Kunkel
Rio Linda, CA
Boosting the springs doesn't change the position of the lower control arms.
[Re: John_Kunkel]
#2087268
06/06/16 07:34 PM
06/06/16 07:34 PM
dogdays
Hey, it's a nice looking car.
Took me a while to figure out that (figuratively) sliding the spindle up slides the LCA down. If that's hitting you're sort of stuck. Possible solutions include taller tires, higher spring rate springs, and shocks, stiffer on compression. So swapping spindles back looks like an easier thing to do.
Now the problem of the top of your tire showing. I bet you'll be able to live with that. But if someone convinces you to fix it, you'll either have to move the entire front clip down, channeling it over the frame, or else move the lower edge of the fender lip down. Neither of those sound very easy either.
So it probably won't win the Ridler Award for next year, but it will get attention on the road. Good job!
R.
