Re: Stuff Happens
[Re: quickd100]
#2086486
06/05/16 04:51 PM
06/05/16 04:51 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
You are definitely better off finding it when you still HAVE some oil pressure.
Mopar to the bone!!!
Re: Stuff Happens
[Re: quickd100]
#2095626
06/21/16 01:41 PM
06/21/16 01:41 PM
Posts: 7,490 Minnesota
Hemi_Joel
Minnesota
Dave, did you find the cause?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Stuff Happens
[Re: quickd100]
#2095681
06/21/16 03:17 PM
06/21/16 03:17 PM
Posts: 43,173 Bend,OR USA
Cab_Burge
Check the bypass valve in the oil pump cover first It should slide in and out easily, if it is galled up from the metal it won't Good luck, hopefully it is something simple
