Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? #2086095
06/04/16 11:01 PM
06/04/16 11:01 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
So the application is a turbo slant six, under 300hp, never will see the drag strip, likely never will get north of 5k RPM. a QT scattershield from Summit is nearly $800. I will likely get a custom SFI rated alum FW/pressure plate set-up. I have an alum OEM bellhousing. CF/Kevlar is not a hassle for me. Anybody think adding say a 1/4"? outside/bonded Kevlar/CF to the complete outside of the OEM housing make any sense? Has to be better then nothing. Lot cheaper then the QT, and then spend the savings on the FW/clutch. Well?
Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? [Re: jcc] #2086100
06/04/16 11:21 PM
06/04/16 11:21 PM
IN
ahy Offline
ahy  Offline
IN
Not sure why you would need more than the AL bell housing? No strip, under 300 HP, under 5000 RPM.
Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? [Re: jcc] #2086110
06/04/16 11:38 PM
06/04/16 11:38 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Sounds like a waste òf time and money to me shruggy I also have to question the aluminium flywheel as well in this application. I would think a steel flywheel with a counterweight pressure plate and iron disc would do the trick.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? [Re: jcc] #2086122
06/05/16 12:07 AM
06/05/16 12:07 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
You can use a trans blanket,would be less expensive.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? [Re: jcc] #2086128
06/05/16 12:20 AM
06/05/16 12:20 AM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Do it, test it to failure. Get an sfi rating, go into business and become filthy rich by giving them a 2 year from date of manufacture expiration.
Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? [Re: ahy] #2086268
06/05/16 11:28 AM
06/05/16 11:28 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
I agree, the need is minimal if at all, more likely a little more peace of mind, without spending $800.
Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? [Re: fourgearsavoy] #2086271
06/05/16 11:30 AM
06/05/16 11:30 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
Gus beer
Not the first time I have heard that before. grin Alum flywheel is thinking because its a 76?lb crank, no drar launch needed, and it may see some AutoX, hence my alum thinking.
Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? [Re: hemi-itis] #2086274
06/05/16 11:33 AM
06/05/16 11:33 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
Interesting, but not sure if I have clearance, easily, and curious how it secures on the most sloped portion of the bellhousing where a flywheel would likely radiate thru, in a failure. Has this been done before? work
Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? [Re: Bill MeLater] #2086275
06/05/16 11:35 AM
06/05/16 11:35 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
I need to get even richer, think I can lobby for a shorter 1 year expiration for the sake of "safety"? biggrin
Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? [Re: jcc] #2086285
06/05/16 11:48 AM
06/05/16 11:48 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Sounds like you have access to the C/F cheap or free
so I would do it... is it needed.. doubt it but sure
would be a good test... the hood on my car I built
out of C/F.. sure did make it lighter(and no one made
anything for that car)
wave
Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? [Re: jcc] #2086288
06/05/16 11:52 AM
06/05/16 11:52 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Unless you use the 3.09:1 box, or a very high (numerical) axle, the light flywheel will require you to drive it like a 2-stroke. Not fun in traffic.
Boffin Emeritus
Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? [Re: MR_P_BODY] #2086294
06/05/16 11:57 AM
06/05/16 11:57 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
My supplies are not free unfortunately, but certainly cost effective. Three things I still would like to figure out, what does a steel QT housing weigh, so I can see if I am getting any weight benefits, what temps is the housing likely to see from internal heat vs external exhaust, which I can shield ( need this to make sure I use correct epoxy), and then how am I going to contain and fasten the open bottom?
Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? [Re: polyspheric] #2086296
06/05/16 12:04 PM
06/05/16 12:04 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
Yes, I am very hesitant on this choice, but I need a custom flywheel, to get the rating, and the torgue rating for a better clutch set-up, car is headed towards 2500lbs, with a short tire 23"?, of course the turbo, but it will have 2.76, and you are correct, very street focused, eek I'm thinking. work
Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? [Re: jcc] #2086300
06/05/16 12:07 PM
06/05/16 12:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I assume you will vac this thing(all the light weight
C/F parts have a vac applied to pull out all the extra resin)
once the vac is applied the part tends to stay in place
wave
Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? [Re: MR_P_BODY] #2086311
06/05/16 12:24 PM
06/05/16 12:24 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
Yes, it will be bagged.
Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? [Re: jcc] #2086352
06/05/16 01:11 PM
06/05/16 01:11 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Take pics as you go. I'd like to see what your up to.
All I can add is if you blow a flywheel up I don't think a little carbon is going to slow it down.
Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? [Re: FastmOp] #2086380
06/05/16 01:43 PM
06/05/16 01:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Even on the chevy stuff that uses a flywheel shield
which is basically 1/8" steel they use the grade 8
bolts to slow it down or hold it in... the shield I
looked at looked like it was mild steel.. I could be
wrong on that part... but it sure wasnt thick
wave
Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? [Re: jcc] #2086391
06/05/16 01:52 PM
06/05/16 01:52 PM
Rittman Ohio
Rittman Ohio
Gus beer
Well that's the theory of the aluminium wheel recovering faster between gear changes. As soon as the clutch releases the disc from the clutch/flywheel under load it zings back up instantly to your 5000 RPM sweet spot.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? [Re: jcc] #2086419
06/05/16 02:33 PM
06/05/16 02:33 PM
Az
Crizila Offline
Crizila  Offline
Az
I like the idea. Containment is the big question. How about 3/8" thick? Sure would help address space / linkage issues that accompany blankets and steel shields.
Fastest 300
Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? [Re: jcc] #2086446
06/05/16 03:14 PM
06/05/16 03:14 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
Another option would be to get a copy of the adapter plate Mark Goodman used to make and then find a used small block shield. That also allows you to use the 130 tooth flywheel, but puts the starter in the low position.
Lou (Dart 270) on the Slant board has the one I had made. I think he would loan it out so you could copy it.
