Re: 10 1/2 Tire on 8 1/2 Rim
[Re: notchbackcuda]
#208628
01/30/09 01:39 PM
01/30/09 01:39 PM
Posts: 4,075 Mo.
racerx
Mo.
I'm not sure where to ask this: I'm contemplating running MT 10 1/2 X 31 ET DRAG tires on 8 1/2 Centerlines. With this combination I can get the tire I want under the car (73 Charger) without modifications other than a Doctor Diff Spring Offset. Otherwise, It's tubs or mini-tubs. What kind of trouble am I asking for running a narrower than recommended rim?
Less of a contact patch
[Re: racerx]
#208629
01/30/09 01:41 PM
01/30/09 01:41 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
It won't hurt it. It will be a little narrower and the sidewall will become a little more stiff but it will work fine. I have run a 31*13 on a 10" wheel for years.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: Jacob Pitt]
#208630
01/30/09 03:18 PM
01/30/09 03:18 PM
Posts: 17,923 Akron, Ohio
ProSport
Akron, Ohio
How fast are you going? Car will definitely be more stable on a wider rim. I'm running 10" rims with a 10.5 tire and some run 12" rims.
[Re: notchbackcuda]
#208633
01/30/09 05:37 PM
01/30/09 05:37 PM
Posts: 13,382 Marion, South Carolina [><]
an8sec70cuda
Run it, you won't have any trouble. I've done it for years, have many friends doing it on some fast stuff, never any trouble. CHIP
[Re: notchbackcuda]
#208634
01/30/09 05:47 PM
01/30/09 05:47 PM
Posts: 43,274 Bend,OR USA
Cab_Burge
If your running the 10.5x31x15 W tire you need a wider rim like Bobr has said, if it is a non W tire you will probally fight getting the best contact patch with the 8 inch wide rim versus a 10 inch. I have ran the smaller M/T 26x10 and 29x10.5 wide tires on 8.5 inch wide rims and that work fine as far as I could tell, I never swapped those size tires onto a 10 inch or wider rim and ran them with the rim change only so I did change rims sizes on my old NHRA A/SA stocker with 9x30x15 slicks from a 8 inch wide rim to a 10 inch wide rim, that car like that a lot Different animal tho so we can't really compare your car to mine back then
[Re: an8sec70cuda]
#208635
01/31/09 01:11 AM
01/31/09 01:11 AM
Posts: 8,165 Left Coast
BobR
Left Coast
WHY?
