70 Roadrunner - How to Re-Connect Brake Booster Linkage???
#2086258
06/05/16 11:01 AM
06/05/16 11:01 AM
Posts: 959 Chicago
PurpleBeeper
Chicago
Does anyone know a good trick to re-connect the brake pedal linkage to the back of a brake booster? My car is a 70 Roadrunner with power disc/drum. I did this job once before and remember it was a major PIA...and it still is. I was "barely" able to get the booster/bracket bolt out to remove the old brake booster & I've worked on trying to get the bolt back in for 3 hours without any luck. Any tricks? I'm starting to consider taking the booster back out, attaching the linkage and try to "thread the needle" to get it all back in place with the linkage attached. Any help is appreciated.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
Re: 70 Roadrunner - How to Re-Connect Brake Booster Linkage???
[Re: PurpleBeeper]
#2086289
06/05/16 11:53 AM
06/05/16 11:53 AM
Posts: 601 Mass
charge70
Mass
I usually put the booster in with the linkage already on it.I've never tried it the way your doing it.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: PurpleBeeper]
#2086320
06/05/16 12:32 PM
06/05/16 12:32 PM
Posts: 959 Chicago
PurpleBeeper
Chicago
Thanks charge70.... it's possible, but I tell you what, it's almost impossible. I will pull the booster out and try it your way.
[Re: charge70]
#2086755
06/05/16 11:41 PM
06/05/16 11:41 PM
Posts: 959 Chicago
PurpleBeeper
Chicago
I usually put the booster in with the linkage already on it.I've never tried it the way your doing it. Worked a 100 times better putting the linkage on first. THANKS!
