Due to a bad mini-starter I damaged the converter as well, and would like to know what you think would be suitable.
512 cui
12.4 static comp
about 9.2 dynamic comp
2.91 rear sure grip
TF-2 shift kit, bands and clutches beefed up, bolt-in sprague etc.
Cam is a fairly mild Lunati xxx703 (
http://www.lunatipower.com/Product.aspx?id=1579&gid=362)
Stealth unported heads with 1.6 roller rockers
Mopar M1 single plane intake with E85 port injection.
Hooker 1 7/8" headers with full 2 1/2" exhaust.
Car (67 Charger) is street driven with the occasional burnout.
Do you think this converter B&M 10415 - B&M Holeshot Torque Converter would be suitable?
http://www.bmracing.com/products/10415-t...dodge-plymouth/ Or would something else be better?
