73-74 B Body frame ties #208559
01/30/09 11:09 AM
01/30/09 11:09 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Looking for advice, help, etc on tieing the frame on a 73 b body. Any advice, links, etc greatly appreciated.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: 73-74 B Body frame ties [Re: Von] #208560
01/30/09 12:15 PM
01/30/09 12:15 PM
Ontario
5537SG Offline
super gas
5537SG  Offline
super gas
Ontario
I made my own out of 3/16" wall 1"x2" tubing, and tied my main hoop into the as well.
I would have preferred larger dimensional material, but when you consider what youre welding it to, I dont think theres a need for bigger. Also, it fits tight to the floor without having to cut it, and they arent visible from the side of the car.
Good luck with yours.
Re: 73-74 B Body frame ties [Re: 5537SG] #208561
01/30/09 01:13 PM
01/30/09 01:13 PM
California, USA
P
Phil Saran Offline
Phil Saran  Offline
P
California, USA
OK, mine's a "A" body, but I used 3/16" thick
2"x3" square tubing and my main hoop also tie into it.
It butts up against the floor nice and tight.
Re: 73-74 B Body frame ties [Re: Phil Saran] #208562
01/30/09 02:16 PM
01/30/09 02:16 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Let me clear up a little what Im asking. Since the 73 up b bodies use the differnt k frame, isolator stuff, does anybody make a prefabbed connector? If not, any pics on how you fabbed your own?
Re: 73-74 B Body frame ties [Re: Von] #208563
01/30/09 05:26 PM
01/30/09 05:26 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Sorry Von, don't have any pics but what I did on my '74 was to use 2X3 tubing and connect the vertical wall of the front sub frame to the vertical wall of the rear sub frame. To do this we had to cut out a section of the floor and weld the connector into the floor. Some of the connector will protrude into the rear floor pan but it connects the whole car together and is really strong.
I can blow your mind how I was able to get rid of the rear torsion bar X-member and use the early model b-body torsion bars if you like. (Might have pictures of this somewhere)
Re: 73-74 B Body frame ties [Re: torkrules] #208564
02/01/09 01:07 AM
02/01/09 01:07 AM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Someone sent me a PM about the torsion bar cross member elimination, but like an idiot, I erased it by accident. I'll try to post picks as soon as I find them.
