Torque converter suggestions for Lunati 60302 in 440 Six BBL #2085072
06/03/16 09:51 AM
06/03/16 09:51 AM
N.E. Ohio
K
KillerBee Offline OP
K
N.E. Ohio
I need to determine what torque converter would be best for my wife's Challenger.
This is a mild street car that will be driven around our area, possibly with grandkids on board, to cruise ins and shows including some highway driving.
Would like decent performance from the car but drivability is the main priority.
Engine is a 1968 440 with original stock forged internals that has been cleaned, honed and assembled with new rings and bearings.
Heads are aluminum unported Stealths with better retainers and locks.
727 transmission has been rebuilt with shift kit and standard (non manual) valve body
Hooker 1 7/8" headers with full 2 1/2" exhaust.
Induction is a stock Six Pack setup
Cam is Lunati 60302:
•Advertised Duration (Int/Exh): 262/268
•Duration @ .050 (Int/Exh): 220/226
•Gross Valve Lift (Int/Exh): .475/.494
•LSA/ICL: 112/108
•Valve Lash (Int/Exh): Hyd/Hyd
•RPM Range: 1400-5800
Going to start with 3.23 Sure Grip rear but have a 3.55 center section if we're not happy with the 3.23
Not looking for a custom built, big dollar, high stall converter but something that stalls between 2000-2400?
A couple reputable builders who aren't trying to sell me their products have suggested a Dacco 359 non lock up.
Any advice or suggestions?
Thanks.
Re: Torque converter suggestions for Lunati 60302 in 440 Six BBL [Re: KillerBee] #2085090
06/03/16 10:41 AM
06/03/16 10:41 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I used a Mopar 175k converter in a mild 440 build (twice) they worked well for me. and they were pretty affordable.
Coming soon!!!!
Re: Torque converter suggestions for Lunati 60302 in 440 Six BBL [Re: KillerBee] #2085091
06/03/16 10:41 AM
06/03/16 10:41 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Call PTC and discuss what you want. Much better chance of getting what you want the first time that way.
Master, again and still
Re: Torque converter suggestions for Lunati 60302 in 440 Six BBL [Re: DaveRS23] #2085094
06/03/16 10:48 AM
06/03/16 10:48 AM
None
71rm23 Offline
71rm23  Offline
None
Agree. Got mine from them great people
Re: Torque converter suggestions for Lunati 60302 in 440 Six BBL [Re: KillerBee] #2085122
06/03/16 11:35 AM
06/03/16 11:35 AM
NEW HAMPSHIRE AND MAINE
BIGSTROKER Offline
BIGSTROKER  Offline
HUGHES 24-30HD
Re: Torque converter suggestions for Lunati 60302 in 440 Six BBL [Re: KillerBee] #2085519
06/03/16 09:05 PM
06/03/16 09:05 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Assuming a 28" tire, I'd be thinking about 2400 stall, but as stated previously, ask a couple of converter guys for their input.
Re: Torque converter suggestions for Lunati 60302 in 440 Six BBL [Re: KillerBee] #2085546
06/03/16 09:49 PM
06/03/16 09:49 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Stock is where I would start. Do you have the stock converter?
Re: Torque converter suggestions for Lunati 60302 in 440 Six BBL [Re: BSB67] #2085566
06/03/16 10:21 PM
06/03/16 10:21 PM
N.E. Ohio
K
K
N.E. Ohio
I have the converter that was in the car.
I have no idea if it's stock or in good condition or not.
I was planning on using it for a core.
I'm told the Dacco 359 is the stock 12" converter used in Six Pack cars but not externally balanced.
Around 2200 stall.
Re: Torque converter suggestions for Lunati 60302 in 440 Six BBL [Re: KillerBee] #2088235
06/08/16 10:42 AM
06/08/16 10:42 AM
gregsdart Offline
gregsdart  Offline
A stock 383 hp converter ,(10 3/4 inch core) which was also used behind the 340 and Hemi, would stall about 2600 to 2800 rpm. Just be sure it is the hi stall version of that core. I think there was a low and a hi stall. This to me would be the best option for a street car with a mild cam. More stall may be a touch faster with street tires, but not worth the down side unless you spend extra $$ for a special converter. A stock replacement is what I am thinking, just be sure on the stall it is set for.
Re: Torque converter suggestions for Lunati 60302 in 440 Six BBL [Re: gregsdart] #2088702
06/08/16 11:27 PM
06/08/16 11:27 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
What Greg said. I have that cam in a 70 GTX with ported 906's and roughly 8.75-1 comp. HP exhaust manifolds, Holley S.D. and a 625 Edelbrock. 323 gears and the Hemi/RR converter that stalls at 2600 and it fries the tires at will, cruises great at hiway speed. It is a very good choice for your combo and fairly inexpensive.
Re: Torque converter suggestions for Lunati 60302 in 440 Six BBL [Re: BSB67] #2088713
06/08/16 11:39 PM
06/08/16 11:39 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
this! a stock converter and 3.23 gear will work fine with that small cam.
Re: Torque converter suggestions for Lunati 60302 in 440 Six BBL [Re: KillerBee] #2088715
06/08/16 11:42 PM
06/08/16 11:42 PM
Kirkland, Washington
Pacnorthcuda Offline
Stock converter should do fine in that application.
Re: Torque converter suggestions for Lunati 60302 in 440 Six BBL [Re: KillerBee] #2088743
06/09/16 12:17 AM
06/09/16 12:17 AM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
the Dacco TC #359 you describe, when I googled it, shows:
67-76 6cl/318
69-72 383 2bbl
72-76 400 forged crank
that's from a 2012 catalog I found online - I picked up a Dacco #766 which is a rebuilt 11" hemi TC - 24-2700 stall I think..., my brother picked up a Big End Motorsports TC #32008 for me for my birthday - 11" 24-2700 stall also - so I have to choose -
my combo is a 440-6, .030 over, Lunati 10230703K kit - 271/279 duration, 494/513 lift, supposed to be good 1800-6200 and likes a 24 and up stall TC, '71 carbs, alum intake, basically stock rebuild w/906 heads, exhaust manifolds, trans is a BUILT 727 - all premium guts/clutches - very tough - 2.5" exhaust w/X pipe, dynomax ultraflows, 8 3/4 w/3.55 new SG...just check your Dacco #
Re: Torque converter suggestions for Lunati 60302 in 440 Six BBL [Re: KillerBee] #2088908
06/09/16 10:13 AM
06/09/16 10:13 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i've run 223/233@.050", .505"/.515" lift, 110lsa camshaft with the stock 11 3/4" converter in a 9.3:1 compression 440 with absolutely no issues. this actually drove and performed best with a 3.23 gear.
