challenger flip top gas caps
#2084199
06/01/16 05:53 PM
06/01/16 05:53 PM
Posts: 223 Oreland Pa
clonedshaker+6
Oreland Pa
hi everyone i am wondering if the screw on gas cap under the flip top is available in a vented form. i have a modified stock tank and neck in my car and its going to need a Vented cap. i can only seem to find Non vented. if anyone can point me in the right direction that would be great. thanks!
71 challenger 440 sixpack shaker *CLONE* (71challenger 440+6 shaker clone FAST/my HS grad present) 03 mustang Mach 1 (daily driver)
11.35 @ 121.5 4 SPEED on F60-15s w/ 6/32 tread
Re: challenger flip top gas caps
[Re: clonedshaker+6]
#2084426
06/02/16 01:19 AM
06/02/16 01:19 AM
Posts: 18,157 Mass
DAYCLONA
Mass
hi everyone i am wondering if the screw on gas cap under the flip top is available in a vented form. i have a modified stock tank and neck in my car and its going to need a Vented cap. i can only seem to find Non vented. if anyone can point me in the right direction that would be great. thanks! IIRC the 70 Challenger gas cap is non vented, unless N95 equipped, and 71 up are pressure/vacuum rated caps which allows for suction and vapor release at the cap depending on the tanks volume/pressure/siphoning in a round about way "vented"?
[Re: cruzin]
#2084811
06/02/16 08:08 PM
06/02/16 08:08 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
The original gas cap used on the Challenger flip-top gas caps were not vented. Perhaps there's a vented cap that fits and is vented. However, another option is to drill a small hole in your existing cap for venting. I did this on my Challenger flip top gas cap (I used an aftermarket locking gas cap) and it works fine. Some of them had to vented. I own two Sixpack 70 Challengers and they are both flip top gas caps and N-95 California cars. Both cars have locking gas caps under the flip tops. Was this the solution for N-95 cars? I don't know but the gas tanks require a vented cap.
