challenger flip top gas caps #2084199
06/01/16 05:53 PM
06/01/16 05:53 PM
Oreland Pa
clonedshaker+6 Offline OP
Oreland Pa
hi everyone i am wondering if the screw on gas cap under the flip top is available in a vented form. i have a modified stock tank and neck in my car and its going to need a Vented cap. i can only seem to find Non vented. if anyone can point me in the right direction that would be great. thanks!
71 challenger 440 sixpack shaker *CLONE* (71challenger 440+6 shaker clone FAST/my HS grad present)
03 mustang Mach 1 (daily driver)
11.35 @ 121.5 4 SPEED on F60-15s w/ 6/32 tread
Re: challenger flip top gas caps [Re: clonedshaker+6] #2084225
06/01/16 06:55 PM
06/01/16 06:55 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
The original gas cap used on the Challenger flip-top gas caps were not vented. Perhaps there's a vented cap that fits and is vented. However, another option is to drill a small hole in your existing cap for venting. I did this on my Challenger flip top gas cap (I used an aftermarket locking gas cap) and it works fine.
Re: challenger flip top gas caps [Re: clonedshaker+6] #2084405
06/02/16 12:36 AM
06/02/16 12:36 AM
BDW Offline
BDW  Offline
What size hole did you drill?
Re: challenger flip top gas caps [Re: clonedshaker+6] #2084426
06/02/16 01:19 AM
06/02/16 01:19 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
IIRC the 70 Challenger gas cap is non vented, unless N95 equipped, and 71 up are pressure/vacuum rated caps which allows for suction and vapor release at the cap depending on the tanks volume/pressure/siphoning in a round about way "vented"?
Re: challenger flip top gas caps [Re: BDW] #2084621
06/02/16 02:04 PM
06/02/16 02:04 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
I can't recall exactly however, it's small hole, like a 5/64" or 3/32". Unless you looked, you wouldn't even notice it. You can always increase the opening if you need to.
Re: challenger flip top gas caps [Re: cruzin] #2084811
06/02/16 08:08 PM
06/02/16 08:08 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Some of them had to vented. I own two Sixpack 70 Challengers and they are both flip top gas caps and N-95 California cars.
Both cars have locking gas caps under the flip tops. Was this the solution for N-95 cars? I don't know but the gas tanks require a vented cap.
Re: challenger flip top gas caps [Re: Morty426] #2084976
06/03/16 12:47 AM
06/03/16 12:47 AM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
Read this old thread. LINK
