Re: did I dodge the bullet? [Re: NoFrills] #2084718
06/02/16 05:44 PM
06/02/16 05:44 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Originally Posted By NoFrills
I looked some more at the block and treads and did not see any issues. Im going to borrow a tread checking tool off a machinist friend this weekend. Was talking to a buddy with a superstock car he told me to get rid of the fluidampener thats on the car. Said they dont work over 6000 rpm.
My 572 has had a Fluid-Damper on for 300 passes at 7000 rpm. Bearings looked excellent on tear down. Don't know how much power it makes but it has been as quick as 9.02@151, 3350lbs
Doug
Re: did I dodge the bullet? [Re: NoFrills] #2084753
06/02/16 06:38 PM
06/02/16 06:38 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Don't just glance in there and "have a look". You better get the motor out, completely down it and have a VERY close look at the main webs. Nuts don't "just come off" main studs. And as I said earlier, I would be surprised if untorqued main studs would keep the nuts on for ONE burnout, much less a few passes. I hope not, but am betting on cracked block, broken crank, or both
The dampner is NOT the problem
Re: did I dodge the bullet? [Re: NoFrills] #2084838
06/02/16 09:13 PM
06/02/16 09:13 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Great job catching the oil pressure through the traps. I always tell myself at the beginning of each day to check the gauges at the top of every run. I never remember to look until I'm on the return road.
Re: did I dodge the bullet? [Re: NoFrills] #2085963
06/04/16 06:33 PM
06/04/16 06:33 PM
East Brunswick New Jersey
N
NoFrills Offline OP
NoFrills  Offline OP
N
Well the ening is out and apart. I really want to find a crack or something wrong but I can't. I guess i'm going to bolt it back togeather and hope for the best.
Re: did I dodge the bullet? [Re: dvw] #2085972
06/04/16 06:53 PM
06/04/16 06:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Doug
My 395ci and my 416 both have a Fluidamper on them..
the 395 has had it on for years now.. turns 8100 each
pass.. Its apart right now.. it looks great.. I just had
the pan off the 416 yesterday and had the #5 main off of
it.. looked new still
wave
Re: did I dodge the bullet? [Re: NoFrills] #2086190
06/05/16 03:10 AM
06/05/16 03:10 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Do they make a stretch gauge fixture for torquing ARP studs?
I remember an article in Hotrod years ago about them losing a rod in a SBC after the bolts came loose. They found the nuts in the pan. When they checked the stretch after torquing to factory specs they found the bolts weren't close to tight. It ran for a while too before it went boom.
Maybe that's what happened here. Partially/improperly torqued fastener held on for a while and then fell apart.
Kevin
