Re: did I dodge the bullet?
[Re: NoFrills]
#2084163
06/01/16 05:06 PM
06/01/16 05:06 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
Run down and buy yourself some power ball tickets!
Have a great day Iowan
"obsolete is neat"
[Re: Iowan]
#2084169
06/01/16 05:08 PM
06/01/16 05:08 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I think they wrote a song about you..it's called lucky man
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: NoFrills]
#2084175
06/01/16 05:12 PM
06/01/16 05:12 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Sounds like it wasnt torqued... put it back together and TORQUE... ALL OF THE MAINS AND RODS... prime the oil system with a drill.. you should see 70#... if all is good... beat on it...... and buy some lottery tickets
[Re: NoFrills]
#2084193
06/01/16 05:47 PM
06/01/16 05:47 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
You did dodge the bullet. But when is the next one getting fired at you?
I have bought a few TK race cars in my day and every one would come apart (Motor/trans out for inspection or most likely a refresh. Rear end apart and looked at, etc...)I suggest you really need to do that now after finding this. What else isn't right??
Not only will the inspection/freshen up process potentially save you money in the long run you will now KNOW the condition of your new race car. As a bonus, it could also save you from personal harm if a mechanical defect results in a crash.
Now...ask me how I know. As a youngster I bought a "proven, fresh, race ready car. Turn key just add driver". Made a 1/2 track lap and then on the first full run into the program, lost a rod at 800' oiled the track and my rear tires and after watching the tower pass across my windshield a few times I managed to save it/was really lucky that I gathered it up going straight down the track, albeit in the other lane. It was also lucky that it was a solo TnT run and no one was next to me.
Doing the autopsy, I found all the rod bolts were snugged up; no where near torque spec.
Yes, [censored] can happen with these cars all the time. Just do your due diligence to minimize your risk.
[Re: NoFrills]
#2084200
06/01/16 05:53 PM
06/01/16 05:53 PM
Posts: 11,621 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Being lucky is not exactly what im know for thats what scares me. I think I better put a wrench on every nut and bolt I can find. I'll second that vote. Better look at the rest of the car too. That stuff didn't just fall of on that pass. It was loose and rattling around for awhile before it shook off into the pan. I would look at the bolts and studs and replace them if they are no names. Soft fasteners stretching would let the hardware come loose. Check the threads in the block also.
[Re: NoFrills]
#2084228
06/01/16 06:57 PM
06/01/16 06:57 PM
Posts: 4,457 Washington
madscientist
Washington
You better pull it out and look at it. What else wasn't torqued? What else isn't correct?
Dodging one bullet. Dodging two is just insane, and probably won't happen.
[Re: Pacnorthcuda]
#2084239
06/01/16 07:11 PM
06/01/16 07:11 PM
Posts: 43,237 Bend,OR USA
Cab_Burge
I think they wrote a song about you..it's called lucky man ummmm, THAT guy dies in the end Dude, we all die in the end, DON"T fear it Life is a journey we get to take from birth, enjoy the trip Learn from your errors and don't repeat them Enjoy the good times amd good experiences you have along the way
[Re: Cab_Burge]
#2084262
06/01/16 08:04 PM
06/01/16 08:04 PM
Thumperdart
State of confusion
I think they wrote a song about you..it's called lucky man ummmm, THAT guy dies in the end Dude, we all die in the end, DON"T fear it Life is a journey we get to take from birth, enjoy the trip Learn from your errors and don't repeat them Enjoy the good times amd good experiences you have along the way I must be doing it wrong............
[Re: Thumperdart]
#2084264
06/01/16 08:08 PM
06/01/16 08:08 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
I think they wrote a song about you..it's called lucky man ummmm, THAT guy dies in the end Dude, we all die in the end, DON"T fear it Life is a journey we get to take from birth, enjoy the trip Learn from your errors and don't repeat them Enjoy the good times amd good experiences you have along the way I must be doing it wrong............ You and me both. OP; yeah, go buy some lotto tickets. The Gods have given you a sign.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: Airwoofer]
#2084290
06/01/16 09:06 PM
06/01/16 09:06 PM
MR_P_BODY
What about the cam / lifters? Where do they get oil on a SB? Stock it oils up through the heads and through the shafts... or you can plug the heads and oil through the lifters and PRs to the rockers.. I've done both ways.. if its the little shafts(per cylinder) you need to oil via PRs and or spray bars
[Re: NoFrills]
#2084688
06/02/16 04:40 PM
06/02/16 04:40 PM
madscientist
Washington
I looked some more at the block and treads and did not see any issues. Im going to borrow a tread checking tool off a machinist friend this weekend. Was talking to a buddy with a superstock car he told me to get rid of the fluidampener thats on the car. Said they dont work over 6000 rpm. It ain't the FD. Look for something else. I turned my car 8800 all the time and NEVER had a failure like you did. And I ran stock 340 cranks. I knocked many rods out because the oil timing is off. But never an issue with mains.
[Re: NoFrills]
#2084718
06/02/16 05:44 PM
06/02/16 05:44 PM
Posts: 9,861 MI, usa
dvw
MI, usa
I looked some more at the block and treads and did not see any issues. Im going to borrow a tread checking tool off a machinist friend this weekend. Was talking to a buddy with a superstock car he told me to get rid of the fluidampener thats on the car. Said they dont work over 6000 rpm. My 572 has had a Fluid-Damper on for 300 passes at 7000 rpm. Bearings looked excellent on tear down. Don't know how much power it makes but it has been as quick as 9.02@151, 3350lbs Doug
[Re: NoFrills]
#2084753
06/02/16 06:38 PM
06/02/16 06:38 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Don't just glance in there and "have a look". You better get the motor out, completely down it and have a VERY close look at the main webs. Nuts don't "just come off" main studs. And as I said earlier, I would be surprised if untorqued main studs would keep the nuts on for ONE burnout, much less a few passes. I hope not, but am betting on cracked block, broken crank, or both
The dampner is NOT the problem
[Re: NoFrills]
#2084838
06/02/16 09:13 PM
06/02/16 09:13 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Great job catching the oil pressure through the traps. I always tell myself at the beginning of each day to check the gauges at the top of every run. I never remember to look until I'm on the return road.
[Re: dvw]
#2085972
06/04/16 06:53 PM
06/04/16 06:53 PM
MR_P_BODY
I looked some more at the block and treads and did not see any issues. Im going to borrow a tread checking tool off a machinist friend this weekend. Was talking to a buddy with a superstock car he told me to get rid of the fluidampener thats on the car. Said they dont work over 6000 rpm. My 572 has had a Fluid-Damper on for 300 passes at 7000 rpm. Bearings looked excellent on tear down. Don't know how much power it makes but it has been as quick as 9.02@151, 3350lbs Doug My 395ci and my 416 both have a Fluidamper on them.. the 395 has had it on for years now.. turns 8100 each pass.. Its apart right now.. it looks great.. I just had the pan off the 416 yesterday and had the #5 main off of it.. looked new still
