70 R/T SE Headliner Brd.
#208318
01/30/09 12:43 AM
01/30/09 12:43 AM
Finally finishing up my 70 DY3 440-6 R/T SE Challenger. My original headliner backing board (perf. particle board) is warped in a few areas, and I am leary of trying to straighten it and use it, for fear of it rewarping down the road.
Does anyone know a source for a new/repro. board? I think finding a good original would be tough (and expensive).
Thanks for any tips!
Re: 70 R/T SE Headliner Brd.
#208319
01/30/09 12:45 AM
01/30/09 12:45 AM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
im unaware of at the moment of any reproductions that are out there. I think youll have to make due.
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
[Re: EV2RTSE]
#208322
01/31/09 11:01 AM
01/31/09 11:01 AM
Posts: 1,064 Washington
69440
Washington
I've repaired many of these with the same problem, and here's what I did. Lay the board on a flat table, heat it with steam. Steam seams to actually get the materail wet enough to where you can work with it. Once it's very hot, place a bunch of wieght where the warps are. I simply used a big pile of heavy books and placed them all around, then let it sit overnight. Once it was dry, it held it's shape, and once it's in the car, the overhead console is gonna help hold it in place also. If it's really bad, you night have to use some industrial strenght sticky back velcrow. Earlier poster is correct, as of yet, nobody is repopping em, at least that I'm aware of. Good luck.
[Re: fastmark]
#208327
02/02/09 08:10 PM
02/02/09 08:10 PM
Just out of curiosity, which way did you cut it?
Personally, I would have found another buyer.
