Car broke, want to hire someone in the Los Angeles area
#2083146
05/30/16 11:40 PM
05/30/16 11:40 PM
Posts: 206 Los Angeles CA
xyxxjx
Los Angeles CA
I'm looking to hire someone in the Los Angeles area to get my 73 charger running again. It sounded like something locked up in the engine. I feel it is connected to the knocking sound in the attached video clip. The clip was recorded 5 minutes before it "locked up". The sound had gotten worse over the last week or so before the incident. http://sendvid.com/vsf86p2r
1973 Dodge Charger SE 400 automatic transmission. Curb weight: 3800 lbs. All stock so far.
Goal: Reliable everday driveable warmed up 400 as close to 400hp as possible, then a 470 stroker if need be.
Don't protect a feminist when the collapse comes!
Re: Car broke, want to hire someone in the Los Angeles area
[Re: xyxxjx]
#2083156
05/30/16 11:51 PM
05/30/16 11:51 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Sounds like a rod. And what to you mean by locked up? Won't even turn over?
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: DARTH V8Я]
#2083172
05/31/16 12:20 AM
05/31/16 12:20 AM
xyxxjx
Los Angeles CA
Sounds like a rod. And what to you mean by locked up? Won't even turn over? It was recently repaired for some bend push rods so I wouldn't be suprised if there was more. I'm not sure if the starter is turning the engine over definitely don't sound right.
[Re: xyxxjx]
#2083182
05/31/16 12:35 AM
05/31/16 12:35 AM
DARTH V8Я
Its a TRAP!
I'm not sure if the starter is turning the engine over definitely don't sound right. Its either turning the engine over or it isn't.
[Re: DARTH V8Я]
#2083202
05/31/16 12:54 AM
05/31/16 12:54 AM
xyxxjx
Los Angeles CA
I'm not sure if the starter is turning the engine over definitely don't sound right. Its either turning the engine over or it isn't. Sorry, yes it is turning over. I tried to start it again now that its been a few hours. And the engine acually started up but it sounds like a diesel engine if that makes any sense lots of ticking.
[Re: xyxxjx]
#2083203
05/31/16 12:57 AM
05/31/16 12:57 AM
RapidRobert
And the engine acually started up but it sounds like a diesel engine if that makes any sense lots of ticking. lifter clatter/low (oil) psi for some reason
[Re: RapidRobert]
#2083243
05/31/16 02:40 AM
05/31/16 02:40 AM
xyxxjx
Los Angeles CA
And the engine acually started up but it sounds like a diesel engine if that makes any sense lots of ticking. lifter clatter/low (oil) psi for some reason I did notice the oil gauge act strange a couple of times. One moment the needle was in the middle the next it was all the way down. I didn't pay too much attention to it since several of my gauge don't work (fuel, odometer and clock).
[Re: xyxxjx]
#2083247
05/31/16 02:45 AM
05/31/16 02:45 AM
DARTH V8Я
Its a TRAP!
Bent pushrods usually is over revving assuming you have the stock valve springs. Oil pressure dropping low or zero the recovering means your either:
1. running low on oil 2. oil pump failing
Either way I'm betting you have a spun rod bearing.
[Re: xyxxjx]
#2083249
05/31/16 02:51 AM
05/31/16 02:51 AM
RapidRobert
as you know oil psi is just like blood pressure, you gotta have it. I would pull the dist & intergear & drill prime the pump with a 5/16 hex rod & see what develops for pressure
[Re: DARTH V8Я]
#2083260
05/31/16 03:44 AM
05/31/16 03:44 AM
xyxxjx
Los Angeles CA
Either way I'm betting you have a spun rod bearing. That sounds expensive. I have not been reving the engine, been accelerating slow since most parts on the car are still old. Oil change was about 60 miles ago maybe a month or two.
[Re: xyxxjx]
#2083309
05/31/16 10:44 AM
05/31/16 10:44 AM
DARTH V8Я
Its a TRAP!
It is. Drain the oil into a clean container. Then run a magnet through it to see what it picks up.
[Re: xyxxjx]
#2083333
05/31/16 11:41 AM
05/31/16 11:41 AM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
If it bent another pushrod and tossed a lifter out of a bore then you will not have oil pressure.
Your description makes me think it's a bad or broken rod too. Don't touch that ignition key again.
In all probability, it's time for that motor to come out.
[Re: xyxxjx]
#2083491
05/31/16 05:25 PM
05/31/16 05:25 PM
Posts: 5,445 So Cal
Sinitro
So Cal
These guy are very good... Lancer Automotive 8151 West 3rd Street Los Angeles, CA 90048 Phone: 323.653.1100 Business Hours Monday through Friday 7:30am – 5:30pm Talk to either Lance or Leon.. Just my $0.02...
[Re: xyxxjx]
#2083588
05/31/16 08:31 PM
05/31/16 08:31 PM
xyxxjx
Los Angeles CA
Yes, I'll definitely have it towed somewhere, this is more than I want to mess with. I'm beginning to think this was the problem I experienced in this thread https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2080459/1.htmlIt just coincided with the car wash so I thought it was an eletrical issue.
[Re: feets]
#2083599
05/31/16 08:53 PM
05/31/16 08:53 PM
xyxxjx
Los Angeles CA
If it's this, what price range approximately am I looking at? If it's the other scenario what price range would that be?
[Re: Morty426]
#2083740
05/31/16 11:40 PM
05/31/16 11:40 PM
xyxxjx
Los Angeles CA
Fixing it the cheap way - less than $1000 if you can find someone willing to do it.
The right way will be over $2000 if you are paying someone. You mean if it's a rod bearing issue and not just a push rod?
[Re: xyxxjx]
#2084280
06/01/16 08:55 PM
06/01/16 08:55 PM
feets
Senior Management
Senior Management
Irving, TX
If it bent a pushrod again you really need to figure out why it has developed such an appetite.
The quick fix could be relatively inexpensive.
However, when we get to the bottom end banging, you're talking pulling the engine and going for either a rebuild or replacement. Figure a couple grand to be a starting point and add labor.
[Re: xyxxjx]
#2084355
06/01/16 11:13 PM
06/01/16 11:13 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
The right way will be over $2000 if you are paying someone. You mean if it's a rod bearing issue and not just a push rod? Yep
