Race Trans 904 problem?
#2082862
05/30/16 03:27 PM
05/30/16 03:27 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
my buddy just bought a small block race car. trans was bad so he bought a new Trans from a reputable guy,almost 3k. took it to track and made 1 pass,went great 10.79. thats what it was suppose to do. went to pits ready for another run and NO reverse. Any guesses? still has 1 st. 2nd n 3rd.what could of went wrong?
Hell Hath No Fury Like Mine
Re: Race Trans 904 problem?
[Re: sixpacksteve]
#2082866
05/30/16 03:34 PM
05/30/16 03:34 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
First thing to check would be the shifter cable but I assume that was already checked, just to make sure it's engaging reverse correctly. After that I'll leave it to the trans experts, hopefully it just needs a band adjustment or something.
[Re: ProSport]
#2082868
05/30/16 03:37 PM
05/30/16 03:37 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
wouldn't band adjustment affect 2nd gear also?
[Re: sixpacksteve]
#2082877
05/30/16 03:55 PM
05/30/16 03:55 PM
Posts: 2,117 Byron, NY
W.I.N. Racing
Byron, NY
Sounds like a planetary...I used to strip the splines Check for metal in the pan
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: sixpacksteve]
#2082892
05/30/16 04:21 PM
05/30/16 04:21 PM
Posts: 11,652 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Rear band, strut or servo. Sounds like the reputable guy will be getting it back to fix tomorrow. Stuff happens. Not a big deal, unless the band is broken it should be able to be fixed without coming apart. 1 run old, I would expect he'd take care of it.
[Re: sixpacksteve]
#2082893
05/30/16 04:26 PM
05/30/16 04:26 PM
Posts: 20,201 Park Forest, IL
slantzilla
Park Forest, IL
Does it have a brake in it? Does it still work? Mine won't back up if the brake won't apply.
[Re: slantzilla]
#2082922
05/30/16 05:24 PM
05/30/16 05:24 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I would think either the servo or the strut..if the strut bent.. it might have fallen out.. or the servo itself... both can be checked from the pan.. I would find it hard to be the band adjustment unless he didnt tighten the lock nut
[Re: jpm1916]
#2082983
05/30/16 07:47 PM
05/30/16 07:47 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
he dropped the pan , fluid is Cooked!
[Re: sixpacksteve]
#2082996
05/30/16 08:09 PM
05/30/16 08:09 PM
MR_P_BODY
he dropped the pan , fluid is Cooked! What did the servo and the strut look like... was the servo cocked or the strut bent
[Re: sixpacksteve]
#2082999
05/30/16 08:17 PM
05/30/16 08:17 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
The lack of reverse while still having all 3 forward gears still indicates a problem with the rear band or it's hardware. Cooked fluid will still make it go until the burnt up element is done eating itself up. If the pan is off, look at the that to try to get an idea, but at this point I expect it needs to come apart. Any broken parts in the pan? Rear servo failed and jammed the band on?
[Re: CMcAllister]
#2084203
06/01/16 06:00 PM
06/01/16 06:00 PM
Posts: 1,610 westerly, ri. usa
440lebaron
westerly, ri. usa
904's are always good for breaking rev band, should be piece's in pan
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: sixpacksteve]
#2084216
06/01/16 06:38 PM
06/01/16 06:38 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
$3000.00 for a 10.79 904???
Should be an overkill by a ton type of trans and should have had all the good billet everything, transbrake and good bands... and a nice profit for the builder to boot. Certainly sounds like a rear band issue. If I charged someone that much for a trans for that car I would offer him cash to pay for his trouble and fix it for free. Even the best stuff can break I guess.
[Re: HotRodDave]
#2084233
06/01/16 07:07 PM
06/01/16 07:07 PM
MR_P_BODY
I know plenty of guys in the 9s with a 904 and never broke a band... I would think its the piston is cocked and didnt release
[Re: 440lebaron]
#2084413
06/02/16 12:55 AM
06/02/16 12:55 AM
Posts: 8,326 fredericksburg,va
cudaman1969
fredericksburg,va
904's are always good for breaking rev band, should be piece's in pan The one reason I don't like high idling engines, when put in reverse, that's a lot of pump pressure. It takes a toll after awile.
[Re: cudaman1969]
#2085409
06/03/16 07:04 PM
06/03/16 07:04 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
trans is on its way back to builder. my buddy builds his own tranny's this time he decided to have one professionally built. he doesn't even know whats wrong.or what could of went wrong. we'll know in a few days, i'll post it.
[Re: sixpacksteve]
#2087952
06/07/16 08:37 PM
06/07/16 08:37 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
UPDATE! builder found band cooked off all material and ate into drum when car went across finish line my guy thew it into 1st. gear which is a no no.
