Race Trans 904 problem? #2082862
05/30/16 03:27 PM
05/30/16 03:27 PM
N.Y.
sixpacksteve Offline OP
N.Y.
my buddy just bought a small block race car. trans was bad so he bought a new Trans from a reputable guy,almost 3k. took it to track and made 1 pass,went great 10.79. thats what it was suppose to do. went to pits ready for another run and NO reverse. Any guesses? still has 1 st. 2nd n 3rd.what could of went wrong?
Hell Hath No Fury Like Mine
Re: Race Trans 904 problem? [Re: sixpacksteve] #2082866
05/30/16 03:34 PM
05/30/16 03:34 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
First thing to check would be the shifter cable but I assume that was already checked, just to make sure it's engaging reverse correctly. After that I'll leave it to the trans experts, hopefully it just needs a band adjustment or something.
Re: Race Trans 904 problem? [Re: ProSport] #2082868
05/30/16 03:37 PM
05/30/16 03:37 PM
N.Y.
N.Y.
wouldn't band adjustment affect 2nd gear also?
Re: Race Trans 904 problem? [Re: sixpacksteve] #2082877
05/30/16 03:55 PM
05/30/16 03:55 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Sounds like a planetary...I used to strip the splines
Check for metal in the pan
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Race Trans 904 problem? [Re: sixpacksteve] #2082879
05/30/16 03:57 PM
05/30/16 03:57 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Check the pressure on the rear servo first. Pressure tap is on the passenger side back of the case.
Re: Race Trans 904 problem? [Re: sixpacksteve] #2082884
05/30/16 04:04 PM
05/30/16 04:04 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Rear servo probably let go, There's a retainer in there that was probably never changed out to a good billet one. You're losing pressure now. You can replace it in the car but it is messy an a real pain. Check the new billet rear servos from
A & A Transmissions
Re: Race Trans 904 problem? [Re: sixpacksteve] #2082892
05/30/16 04:21 PM
05/30/16 04:21 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Rear band, strut or servo. Sounds like the reputable guy will be getting it back to fix tomorrow. Stuff happens. Not a big deal, unless the band is broken it should be able to be fixed without coming apart. 1 run old, I would expect he'd take care of it.
Re: Race Trans 904 problem? [Re: sixpacksteve] #2082893
05/30/16 04:26 PM
05/30/16 04:26 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Does it have a brake in it? Does it still work? Mine won't back up if the brake won't apply.
Re: Race Trans 904 problem? [Re: slantzilla] #2082922
05/30/16 05:24 PM
05/30/16 05:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would think either the servo or the strut..if the
strut bent.. it might have fallen out.. or the servo
itself... both can be checked from the pan.. I would
find it hard to be the band adjustment unless he didnt
tighten the lock nut
wave
Re: Race Trans 904 problem? [Re: sixpacksteve] #2082930
05/30/16 05:45 PM
05/30/16 05:45 PM
wilson nc
jpm1916 Offline
jpm1916  Offline
wilson nc
Servo
Re: Race Trans 904 problem? [Re: jpm1916] #2082983
05/30/16 07:47 PM
05/30/16 07:47 PM
N.Y.
N.Y.
he dropped the pan , fluid is Cooked!
Re: Race Trans 904 problem? [Re: sixpacksteve] #2082996
05/30/16 08:09 PM
05/30/16 08:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What did the servo and the strut look like... was the servo cocked
or the strut bent
wave
Re: Race Trans 904 problem? [Re: sixpacksteve] #2082999
05/30/16 08:17 PM
05/30/16 08:17 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
The lack of reverse while still having all 3 forward gears still indicates a problem with the rear band or it's hardware. Cooked fluid will still make it go until the burnt up element is done eating itself up. If the pan is off, look at the that to try to get an idea, but at this point I expect it needs to come apart. Any broken parts in the pan? Rear servo failed and jammed the band on?
Re: Race Trans 904 problem? [Re: CMcAllister] #2084203
06/01/16 06:00 PM
06/01/16 06:00 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
904's are always good for breaking rev band, should be piece's in pan
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Race Trans 904 problem? [Re: sixpacksteve] #2084216
06/01/16 06:38 PM
06/01/16 06:38 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
$3000.00 for a 10.79 904???
Should be an overkill by a ton type of trans and should have had all the good billet everything, transbrake and good bands... and a nice profit for the builder to boot. Certainly sounds like a rear band issue. If I charged someone that much for a trans for that car I would offer him cash to pay for his trouble and fix it for free. Even the best stuff can break I guess.
Re: Race Trans 904 problem? [Re: HotRodDave] #2084233
06/01/16 07:07 PM
06/01/16 07:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I know plenty of guys in the 9s with a 904 and never
broke a band... I would think its the piston is cocked
and didnt release
wave
Re: Race Trans 904 problem? [Re: sixpacksteve] #2084258
06/01/16 07:54 PM
06/01/16 07:54 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Hellooooo...is this thing on? We want to know what broke.
Re: Race Trans 904 problem? [Re: 440lebaron] #2084413
06/02/16 12:55 AM
06/02/16 12:55 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
The one reason I don't like high idling engines, when put in reverse, that's a lot of pump pressure. It takes a toll after awile.
Re: Race Trans 904 problem? [Re: cudaman1969] #2085409
06/03/16 07:04 PM
06/03/16 07:04 PM
N.Y.
N.Y.
trans is on its way back to builder. my buddy builds his own tranny's
this time he decided to have one professionally built. he doesn't even know whats wrong.or what could of went wrong. we'll know in a few days, i'll post it.
Re: Race Trans 904 problem? [Re: sixpacksteve] #2087952
06/07/16 08:37 PM
06/07/16 08:37 PM
N.Y.
N.Y.
UPDATE! builder found band cooked off all material and ate into drum
when car went across finish line my guy thew it into 1st. gear which is a no no.
