How good are oem steel 440 cranks? #2081923
05/28/16 05:48 PM
05/28/16 05:48 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
How much power have you put through a stock steel 440 crank? For how long? Ive heard of breakage before, but only once or twice. I know they are an undercut crank.
Re: How good are oem steel 440 cranks? [Re: Hot 340] #2081927
05/28/16 05:54 PM
05/28/16 05:54 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Stock block, crank, six pack rods, 915 heads. 575 hp 15 years. Still didn't break, but failed magnaflux.
[image][/image]
Re: How good are oem steel 440 cranks? [Re: Hot 340] #2081936
05/28/16 06:19 PM
05/28/16 06:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
How much power are you thinking of putting to one.. I
know a few at 700 hp still living.. they tend to last
longer than the stock blocks.... but the rods
were turned down to chevy size
wave
Re: How good are oem steel 440 cranks? [Re: Hot 340] #2081937
05/28/16 06:23 PM
05/28/16 06:23 PM
Chattanooga, TN
KDY Offline
KDY  Offline
Chattanooga, TN
No real first hand info but Moparbilly's brother's Gremlin is over 800hp with all the kits on and has survived a few Dragweeks. That car has always impressed me since its a factory block and crank going 8.90 @ 150. Hopefully he'll chime in.
Re: How good are oem steel 440 cranks? [Re: Hot 340] #2081947
05/28/16 07:03 PM
05/28/16 07:03 PM
crabman173
crabman173
We used a stock one with mains cut down in Lenny Meltons KOS Dart--it finally made some mid-upper 8 runs all on big NOS--ran for years --suffered through a 727 explosion, bad tuning guessing and I don't know what all until finally getting a super tune up then it just ran and ran and ran The 400 stock block had two bolt stock main caps and is STILL running.
Good tune up--timing right, no detonation and never worry--I have always felt they were stronger than the block.
Re: How good are oem steel 440 cranks? [Re: Hot 340] #2082023
05/28/16 09:52 PM
05/28/16 09:52 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
I had one in my world block for 440 passes. That was one season. I figured I better get it out of there before it broke and killed my block. Car went 8.68 at 154mph. Was in my Lebaron at 2450lbs. Around 750HP
Re: How good are oem steel 440 cranks? [Re: Hot 340] #2082049
05/28/16 10:46 PM
05/28/16 10:46 PM
sing sing
U
unknown Offline
unknown  Offline
U
sing sing
440 steel crank off set ground to chevy 2.1 in a 467ci Hemi, mild street roller. 700 HP??? This was done a LONG time ago but still running strong.
Re: How good are oem steel 440 cranks? [Re: Hot 340] #2082067
05/28/16 11:16 PM
05/28/16 11:16 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
CAST crank 440, indy sr heads, 150 shot of gas, 9.69@135, 200 passes in the 63 Plymouth below. I then spent a heap of cash on a stroker combo and only managed a 9.23@145. Was it worth it ?????
1963 Plymouth Max Wedge
1971 Barracuda
Re: How good are oem steel 440 cranks? [Re: Hot 340] #2082077
05/28/16 11:32 PM
05/28/16 11:32 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Factory 440 crank, turned down to 400 mains, chevy rods, 3.90 stroke. Tune up on the mark, turbos, pump gas, NO 2 STEP. Went low low nines at 3700 lbs for years. Upgraded turbos went 8.80 155 at 3700 lbs.
Re: How good are oem steel 440 cranks? [Re: Hot 340] #2082376
05/29/16 04:36 PM
05/29/16 04:36 PM
New York
polyspheric Offline
polyspheric  Offline
New York
For the same power level, ranked by life expectancy (best = 1st)
1. turbo, supercharge
2. NA
3. nitrous
Major killers:
1. heavy piston
2. high rpm
Remember, inertial load @ TDC exhaust is what breaks rods, and it increases as the square of the rpm - 8,000 is not 14% more than 7,000 (8,000 ÷ 7,000) but 30% more (8,000^2 ÷ 7,000 ^ 2)
Boffin Emeritus
Re: How good are oem steel 440 cranks? [Re: Hot 340] #2082451
05/29/16 07:45 PM
05/29/16 07:45 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
They are not undercut. The fillets are rolled in, "compressed"
Doug
Re: How good are oem steel 440 cranks? [Re: sgcuda] #2082469
05/29/16 08:14 PM
05/29/16 08:14 PM
NC
440Jim Offline
440Jim  Offline
NC
The magnaflux every couple hundred presses is the thing to do if running more than 600 HP. They will crack, but not break right away. So you can catch it before it lets go... If you magnaflux.
The more power, the more often to magnaflux for cracks starting.
Re: How good are oem steel 440 cranks? [Re: Hot 340] #2082807
05/30/16 01:45 PM
05/30/16 01:45 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Every bracket 440 I built over the years that had a stock crank and made over 600hp, when they would come back for freshening, the cranks were always cracked in multiple places......and not tiny little cracks either.
One of the motors had every journal cracked at both ends(two cracks per journal).
They needed a new crank every freshen up.
Re: How good are oem steel 440 cranks? [Re: fast68plymouth] #2082870
05/30/16 03:46 PM
05/30/16 03:46 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Same here. I even stopped magnafluxing them when I took them apart for rebuilds. I would just throw it on the scrap pile and send another crank out to be checked and polished.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: How good are oem steel 440 cranks? [Re: Hot 340] #2082878
05/30/16 03:56 PM
05/30/16 03:56 PM
crabman173
crabman173
No two steps, lite pistons, NO detonation--perfect tune up and they will run until you retire
I have only had two broke 440 steels in 25 years of racing, building etc
They are amazing units--the customers that broke them could have broken an anvil I have bought piles of them and had about 1/2 dozen not mag good but who knows where or how they had been used before that point--they were really well made units compared to everything else Mopar made Those and 727's are Mopars claim to fame IMO
Re: How good are oem steel 440 cranks? [Re: Hot 340] #2082883
05/30/16 04:04 PM
05/30/16 04:04 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
But those are unrealistic goals. A cast crank won't break if you never put it in a position where it could. The simple fact is, when you get to a certain power level, it IS hard on the crank, no matter how much you baby it
Re: How good are oem steel 440 cranks? [Re: Hot 340] #2083469
05/31/16 04:38 PM
05/31/16 04:38 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The old 451 B block stroker had the cutdown stock 440 crank, but light pistons and never reved over 7,000 RPM. I think only around 575 HP?
Re: How good are oem steel 440 cranks? [Re: Hot 340] #2083587
05/31/16 08:27 PM
05/31/16 08:27 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
If you are racing, why push the limits of the stock crank? It's plain old 1053 carbon steel with undercut journals. For a few hundred more, you can have a 4340 alloy steel crank with radiused journals that is at least 50% stronger, maybe 100%. If you break a crank, you could wipe out the rest of the motor, you could dump oil under tires and wipe out your car, and maybe get injured or worse. It's one of the things that costs so little to upgrade, just like stock rods vs. aftermarket, I don't mess around with 50 year old production line time bombs.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: How good are oem steel 440 cranks? [Re: Hemi_Joel] #2083600
05/31/16 08:53 PM
05/31/16 08:53 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Eh. I dunno. It was a legitimate question. With respect, not everything is a "time bomb". But Ill buy a bigger, new crank for it.
Thanks everyone for chiming in.
Re: How good are oem steel 440 cranks? [Re: Hot 340] #2084074
06/01/16 02:35 PM
06/01/16 02:35 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
every stock steel crank I have taken out after 300-400 runs has been cracked. except the last one I did't beleive it had two shops check it both said it was ok ??
