A-Body Fuel Sending Units #2082509
05/29/16 09:33 PM
05/29/16 09:33 PM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
Ok, so who is selling a correct sending unit for a 1970 Duster these days?
This one is from Firestone collectibles (ebay) and was not a low budget price. Not even close to the shape of the cleaned up original in the pic and doesn't fit either.
Re: A-Body Fuel Sending Units [Re: ScottSmith_Harms] #2082516
05/29/16 09:44 PM
05/29/16 09:44 PM
Az
69hemibeep Offline
69hemibeep  Offline
Az
Scott. I got a Spectra Premium from Rock auto for a 68 big block dart 3/8 pick up and it bench tested within the factory specs. Don't know if they do your year or not
1969 Hemi Roadrunner 2nd owner
Re: A-Body Fuel Sending Units [Re: ScottSmith_Harms] #2082579
05/30/16 12:09 AM
05/30/16 12:09 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
None. All seem to have the same source or component parts.
Pick up is higher than stock as it doesn't sit parallel and close to tank floor. Runs out of gas with about 3-4 gallons fuel still in tank. Ratio is goof too with that short float arm. E and F occur at the appropriate times. What happens in between is comical.
Re: A-Body Fuel Sending Units [Re: ScottSmith_Harms] #2082580
05/30/16 12:14 AM
05/30/16 12:14 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Pretty Pathetic
Re: A-Body Fuel Sending Units [Re: ScottSmith_Harms] #2083616
05/31/16 09:23 PM
05/31/16 09:23 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
http://www.kramerauto.com
I bought mine from these guys and it works good. Call them instead of ordering from their website.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: A-Body Fuel Sending Units [Re: ScottSmith_Harms] #2083736
05/31/16 11:33 PM
05/31/16 11:33 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
Scott, I found a NOS unit at Carlisle last year. The pricey repro unit I purchased first was a complete waste of money.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: A-Body Fuel Sending Units [Re: ScottSmith_Harms] #2083850
06/01/16 02:48 AM
06/01/16 02:48 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I'd gladly buy an NOS one if someone has one to sell. Go ahead, gauge me, I need one! smile
Re: A-Body Fuel Sending Units [Re: ScottSmith_Harms] #2083852
06/01/16 02:53 AM
06/01/16 02:53 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Bradsnosparts.com
He has a NOS sending unit
Abe Lincoln
Re: A-Body Fuel Sending Units [Re: ScottSmith_Harms] #2083957
06/01/16 11:23 AM
06/01/16 11:23 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Thanks John, as bad as I'd like to have it there are 3 vendors I will never do business with, Brads, Jims, and G&D.
Re: A-Body Fuel Sending Units [Re: ScottSmith_Harms] #2083962
06/01/16 11:33 AM
06/01/16 11:33 AM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
Fixed it for you!
Re: A-Body Fuel Sending Units [Re: ScottSmith_Harms] #2083990
06/01/16 12:15 PM
06/01/16 12:15 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Fixed it for you!
Yes you did, thanks! cool
Re: A-Body Fuel Sending Units [Re: ScottSmith_Harms] #2084011
06/01/16 12:53 PM
06/01/16 12:53 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
Is your original repairable/ rebuildable?
Kevin
Re: A-Body Fuel Sending Units [Re: ScottSmith_Harms] #2084089
06/01/16 02:49 PM
06/01/16 02:49 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Maybe, I soaked it in Evaporust and soda blasted it but it's still pretty crusty/pitted up.
Re: A-Body Fuel Sending Units [Re: ScottSmith_Harms] #2084134
06/01/16 04:06 PM
06/01/16 04:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thanks John, as bad as I'd like to have it there are 4 vendors I will never do business with:, Brads, Jims, Mitchell and G&D.
fixed it again
Re: A-Body Fuel Sending Units [Re: ScottSmith_Harms] #2084255
06/01/16 07:42 PM
06/01/16 07:42 PM
md
mopars4ever Offline
mopars4ever  Offline
md
http://www.ebay.com/itm/NOS-Mopar-1963-76-A-Body-Gas-Tank-Sending-Unit-/221964357204?hash=item33ae1b4e54:g:WWsAAOSwcBhWaI7b&vxp=mtr
Re: A-Body Fuel Sending Units [Re: ScottSmith_Harms] #2084260
06/01/16 07:57 PM
06/01/16 07:57 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Is the wrong style, and that is the style that ALL reproductions look like.
Re: A-Body Fuel Sending Units [Re: ScottSmith_Harms] #2085645
06/04/16 12:24 AM
06/04/16 12:24 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Abe Lincoln
Re: A-Body Fuel Sending Units [Re: ScottSmith_Harms] #2085664
06/04/16 12:55 AM
06/04/16 12:55 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Thanks John but that is the same style as the repro as well. Look at my first pic, the original is the longer one at the top. I cleaned it up and reused it with a new float and sock. I haven't filled it up yet so don't know if the gauge works or not yet but the car runs on the couple gallons of gas that I put in to get it started.
Re: A-Body Fuel Sending Units [Re: ScottSmith_Harms] #2085991
06/04/16 07:22 PM
06/04/16 07:22 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
you may want to check the rubber seal where the wire connects. The rubber sometimes breaks down mainly due to the cheap alcohol gas
Abe Lincoln
Re: A-Body Fuel Sending Units [Re: ScottSmith_Harms] #2086019
06/04/16 08:12 PM
06/04/16 08:12 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I used a new seal
