Re: A-Body Fuel Sending Units
[Re: ScottSmith_Harms]
#2082516
05/29/16 09:44 PM
05/29/16 09:44 PM
Posts: 1,383 Az
69hemibeep
Az
Scott. I got a Spectra Premium from Rock auto for a 68 big block dart 3/8 pick up and it bench tested within the factory specs. Don't know if they do your year or not
1969 Hemi Roadrunner 2nd owner
#2082579
05/30/16 12:09 AM
05/30/16 12:09 AM
Posts: 27,468 So Cal
autoxcuda
So Cal
None. All seem to have the same source or component parts.
Pick up is higher than stock as it doesn't sit parallel and close to tank floor. Runs out of gas with about 3-4 gallons fuel still in tank. Ratio is goof too with that short float arm. E and F occur at the appropriate times. What happens in between is comical.
#2083852
06/01/16 02:53 AM
06/01/16 02:53 AM
Posts: 16,146 Mesa, Arizona
dart4forte
Mesa, Arizona
Bradsnosparts.com
He has a NOS sending unit
Abe Lincoln
#2084134
06/01/16 04:06 PM
06/01/16 04:06 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
Thanks John, as bad as I'd like to have it there are 4 vendors I will never do business with:, Brads, Jims, Mitchell and G&D. fixed it again
#2085645
06/04/16 12:24 AM
06/04/16 12:24 AM
dart4forte
Mesa, Arizona
http://www.ebay.com/itm/NOS-Mopar-1963-76-A-Body-Gas-Tank-Sending-Unit-/221964357204?hash=item33ae1b4e54:g:WWsAAOSwcBhWaI7b&vxp=mtr
Abe Lincoln
#2085991
06/04/16 07:22 PM
06/04/16 07:22 PM
dart4forte
Mesa, Arizona
Thanks John but that is the same style as the repro as well. Look at my first pic, the original is the longer one at the top. I cleaned it up and reused it with a new float and sock. I haven't filled it up yet so don't know if the gauge works or not yet but the car runs on the couple gallons of gas that I put in to get it started. you may want to check the rubber seal where the wire connects. The rubber sometimes breaks down mainly due to the cheap alcohol gas
Abe Lincoln
