Re: 6 Pack Carb Idles well with Air Fuel Idle Screws Closed
[Re: 3XBlack6packGTX]
#2081997
05/28/16 09:04 PM
05/28/16 09:04 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Also, any opinions on whether center fuel bowl breather tube should be connected by a hose to the valve cover breather or left unconnected and no hose.
thanks for all the help.
Run it to the valve cover if you wish?, using a 2 or 3 nipple breather, as far as leaving it open, an engine/carb fire is possible, not good...so I would put a vacuum cap on the fitting, won't effect anything Mike
[Re: mikemee1331]
#2082283
05/29/16 12:59 PM
05/29/16 12:59 PM
Posts: 1,374 Houston,Tx.
Lee446
Houston,Tx.
You need to check your idle vacumn to determine which power valve you need, manifold vacumn holds the valve closed, not enough allows the valve to open and enrich the mixture. Usually a good rule of thumb is to check your idle vac and if it is, say 10", you would use a power valve marked 5 or 5.5. Since the carbs were rebuilt, I would also check the idle mixture screws on the end carbs, they could be open too much and be contributing to the overich idle. About 1/2 turn out from seated is a good start.
#2082286
05/29/16 01:03 PM
05/29/16 01:03 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Funny. I had a cap on it and someone told me that was wrong and must be left open or vented to breather cap on valve cover. Sounds like I will put the cap back on since my breather has only one port and that goes to my six pack air cleaner port. Thanks again. I think mancini's tilde me I could cap that port when I bought the single port breather.
Great advice. I have several sixpack cars all have the breather/vent on the center's bowl plugged with a vacuum cap, no issues, left open is what the factory did if the carb was vented and there where no provisions or requirements for evaporation control....left open you have a greater chance of a carb fire, and with the faster evporative rate of today gasoline, it's just drying up faster in the bowl if sitting for some time, which leaves you with crusty contaminates to foul the carb's passages...something you don't need esp on a multi carbed vehicle Mike
[Re: 72roadrunnergtx]
#2082315
05/29/16 02:02 PM
05/29/16 02:02 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Capping of the enclosed bowl vent valve hose fitting defeats the purpose external bowl vent valve. The purpose of the vent valve is to provide an external path for the fuel bowl evaporation to improve hot starting. Without the idle bowl vent valve, all fuel vapors collect in the air cleaner through the main bowl vents, creates an over-rich hot start condition. Problem with six-packs, two other fuel bowls without external venting, still a beast to start hot with the air cleaner in place. Agreed, but I'd rather deal with a hot start condition (never experienced that on a sixpack set up, don't jinx me...lol!) than the possibility the needle seat sticks and fuel leaks out the uncapped vent, sprays or puddles on the engine/manifold and the possibility of fire Mike
#2082337
05/29/16 02:45 PM
05/29/16 02:45 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Capping of the enclosed bowl vent valve hose fitting defeats the purpose external bowl vent valve. The purpose of the vent valve is to provide an external path for the fuel bowl evaporation to improve hot starting. Without the idle bowl vent valve, all fuel vapors collect in the air cleaner through the main bowl vents, creates an over-rich hot start condition. Problem with six-packs, two other fuel bowls without external venting, still a beast to start hot with the air cleaner in place. As far as hot start,33 + years,no matter what temp,turn key,couple of rev's and drive it away !
[Re: 62maxwgn]
#2082356
05/29/16 03:48 PM
05/29/16 03:48 PM
RapidRobert
can you up the initial so you can lower the idle speed? 900 just seems high for a mild cam. how many turns in is the idle speed screw? I would cover the basics, float levels/float saturation/float linkage hanging up/fuel psi at idle/power valve blown. all that is left is the idle circuit(s). 6pack newbie but iirc all (3) are contributing to the idle mixture provided to the eng & it's all gonna add up (1 eng but triple the carbs "amount" of idle fuel)
#2082478
05/29/16 08:26 PM
05/29/16 08:26 PM
Posts: 2,077 CA
crackedback
CA
Likely, not enough initial timing, factory specs are not good unless you have to smog test it. Throw the book numbers in the trash and tune it properly, it will run a bunch better. They tend to like 16-20 initial using a stock camshaft. Cleans thing up a bunch! Tailor mechanical advance to hit your total number and run it. He's at 900rpm in DRIVE!!! OP, read this. There's some good info. http://www.moparts.org/Tech/Archive/fuel/7.html
#2082568
05/29/16 11:38 PM
05/29/16 11:38 PM
Posts: 15,377 Omaha Ne
TJP
Omaha Ne
[Re: Sxrxrnr]
#2082682
05/30/16 08:47 AM
05/30/16 08:47 AM
Posts: 2,468 Answering the call of the wild
ThermoQuad
Since you have to disassemble to replace the power valve it would be best if you base-lined your set up by using the guide to tuning six paks. A member here [sogtx] is the six pak guide testing dept. He just set up [base-lined] a set of carbs for an unknown 440 six pak. To the amazement of the shop experts where the car is living it started up,idled & ran beautiful the first time. Nice work Andy! I don't think the bowl vent is the problem here, but as always you cannot troubleshoot a set up with out it being base-lined. Everyone who tries to help forgets this and tries to jump in in the middle of the problem. This is not criticism just an observation. I wish one of them would link every six pak inquiry to the guide so I would have more time to ride [mcycle]. As I work in Technical Support with very complicated technology we achieve proper results with the least amount of pain by starting at the beginning. Thanks to the Lift Off Hood Playground for posting the guide. how to make the six pak work
[Re: ThermoQuad]
#2082757
05/30/16 12:17 PM
05/30/16 12:17 PM
RapidRobert
I wish one of them would link every six pak inquiry to the guide so I would have more time to ride [mcycle]. Noted!
[Re: RapidRobert]
#2082828
05/30/16 02:09 PM
05/30/16 02:09 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
I wish one of them would link every six pak inquiry to the guide so I would have more time to ride [mcycle]. Noted! i think the issue is there are many variations or updates floating around on this site.
[Re: mikemee1331]
#2082947
05/30/16 06:22 PM
05/30/16 06:22 PM
RapidRobert
I did click on the link & had a copy sent to me. No plans for one but someone might ask me to look at there's. If I did run one I'd have the air cleaners poking thru the hood just for the cool factor.
