I keep breaking mini-starters...
#2082181
05/29/16 06:02 AM
05/29/16 06:02 AM
Posts: 208 Norrland, Sweden
Swedcharger67
Norrland, Sweden
I have a 512 with very high cylinder pressure, and yesterday I broke my 2:nd ministarter (common type, low cost, probably Chinese). I'm now in the hunt for a real heavy duty unit, price is less important if it can reliably do the job. What starters do you think I should have a closer look at?
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
Re: I keep breaking mini-starters...
[Re: Swedcharger67]
#2082182
05/29/16 06:22 AM
05/29/16 06:22 AM
Posts: 4,647 aotearoa
rebel
aotearoa
I'm using Nippondenso starters. I had a cheapo Chinese knock off of the same starter. It was a turd. Nippondenso has been bullet proof for years.
[Re: fbs63]
#2082273
05/29/16 12:45 PM
05/29/16 12:45 PM
Posts: 52,972 Romeo MI
MR_P_BODY
A lot of the mini starters hit the block on the starter opening. Its not enough to notice but its enough to break the starter because of the miss alignment. Try sliding some thick paper (Magazine cover works good)between the starter and the block. If it does not go thru, grind the block where its hitting and try again. Do this till you have clearance. As many starters you have broken, it will probably have a witness mark where its hitting. On my BB stuff it hit the block on both a stock block and my mega block.. I also had to take off the plastic part on top of the starter.... no problems on my SB stuff.. I have 2 or 3 of those starters and they have been on my junk for 15 years on the one starter
[Re: Swedcharger67]
#2082371
05/29/16 04:20 PM
05/29/16 04:20 PM
Thumperdart
State of confusion
Dakota truck starter...........
[Re: Thumperdart]
#2082421
05/29/16 06:48 PM
05/29/16 06:48 PM
Swedcharger67
Norrland, Sweden
Thanks for all the good inputs.
I broke the snout off of the first mini-starter, and actually suspected a misalignent. That's why I bought a second unit and I grinded the snout to avoid any tension building up when bolting the starter to the block. Now this 2:nd doesn't seem to have broken the snout off, it spins but it doesn't engage the gears anymore. I suspect the starter shaft may be slightly bent or similar. It anyway hasn't sounded healthy for the last few days so I guess it's ready for the thrash can.
I broke this second unit having the engine management set up for 3 crank revolutions before activating ignition. I will increase this to 6. Cranking ignition was set at -1 degree ATDC. What I also will do is to decrease the dwell time from 4 ms to 3 ms, to try to minimize any risk of premature firing in the coils.
My static compression is 12.4, which shouldn't be a problem. I however have a mild cam allowing for the power brakes to work in town, and this means I have a fairly high cylinder pressure. The dynamic compression is approx 9.2
Thanks again, sounds like a Powermaster is the way to go?
[Re: 590 Challenger]
#2082663
05/30/16 04:14 AM
05/30/16 04:14 AM
Swedcharger67
Norrland, Sweden
Thanks 590, looks like I'm hunting Nippondensos at the moment.
I will try to get a spare unit as well to try to avoid getting stranded somewhere.
[Re: Swedcharger67]
#2083366
05/31/16 01:30 PM
05/31/16 01:30 PM
Swedcharger67
Norrland, Sweden
I ordered a brand new Dodge Dakota 90´s starter, which I thought would be a quality starter... To my disappointment it was exactly the same no-name as those 2 starters I've already broken. The only difference was the 50% price adder at the Mopar/GM dealer.
I'm now looking at 2 Powermaster models: - The 9523 XS Torque which has a billet, replacable nose cone - The 9413 Ultra Torque without a nose cone
Do I need a nose cone or shall go for the more powerful Ultra Torque w/o a nose cone?
Comments appreciated.
[Re: Swedcharger67]
#2083375
05/31/16 01:41 PM
05/31/16 01:41 PM
Posts: 20,202 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Over the years I cut most of the nose cones off my starters so I could change them out quickly between all of our cars. Recently when I went from a powerglide adaptor plate to a JW ultra glide case I had to buy a new starter because the nose cone was needed to locate the starter. There was way to much slop in the mounting holes. Now I will either change out a nose cone or buy another spare to have in my car trailer
