Re: fuel pressure droping ???
[Re: fast414]
#2082021
05/28/16 09:45 PM
05/28/16 09:45 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
Not much help here but I will day good luck!
I had a Carter HV pump on my car and could not get it to work. Tried 2 of them. Same problem as you and I did a bunch of troubleshooting and hit a dead end - and I don't give up easily. Ended up going electric.
I even insulated all the fuel lines in the engine compartment and it did not help.
[Re: fast414]
#2082025
05/28/16 09:56 PM
05/28/16 09:56 PM
RapidRobert
plumb a can of gas in the eng compartment to the pump inlet & retry it. this will eliminate everything rearward from the pump as the culprit (2 short neoprene hoses/long hard line/pickup sock/tank venting). I've heard of the Carter Curse (referring to their mech fuel pumps) but you did say the pump worked fine before (but was it sitting on the shelf along time?)
[Re: fast414]
#2082121
05/29/16 12:54 AM
05/29/16 12:54 AM
RapidRobert
got another pump you can toss in for a quick test (even a stock airtex)
[Re: fast414]
#2082275
05/29/16 12:46 PM
05/29/16 12:46 PM
Posts: 106 waco tx
gogo318
waco tx
Had the same issue on my hauling truck i came to the conclusion that the diaphragm in the pump had a rip in it while it was pumping cool gas the rubber was stiff enough to prevent too much back flow bur as fuel got more warm from being circulated the rubber got softer and just couldnt make enough pressure also had similar issue with the mud truck but that was too much dirt in the tank clogging the sock hope this helps
67 charger fastback 318 stock
67 belvedere II 4dr soft top built 318
68 newport 2dr hard top 318
84 b150 440/727
84 d150 short wheel step side 4x4 lifted
87 omnitruck (you just have to see it )
new addition 63 dart wagon !!!
