Qustion on B5 blue #2081796
05/28/16 12:40 PM
05/28/16 12:40 PM
Finally a HUSKER again
Moparnut426 Offline OP
Where would you guys go for the correct B5 blue paint? PPG, Dupont, House of colors, Martin Senior?
I know that the color can vary a LOT so Im goin to want to make sure I buy more than enough to paint the car out of the same mix.
Kasey
Re: Qustion on B5 blue [Re: Moparnut426] #2081813
05/28/16 01:06 PM
05/28/16 01:06 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
I used Dupont Cromabase with SPI clear on my Cuda. I was very happy with the color match and results. I am sure PPG would proved good color match and coverage as well. When I did my Duster I used Nason acrylic urethane and was also very pleased with the results. For base I would stick to the higher quality paints but I do like the Nason for single stage paint. You do want to make sure you use the right code for the year you have as B5 changed in 71 and again in 74.
Re: Qustion on B5 blue [Re: T2R9] #2081824
05/28/16 01:24 PM
05/28/16 01:24 PM
Florida, US
72ls5fla Offline
72ls5fla  Offline
Florida, US
Here is a 1970 b5 match that is spot on. It was done by mike Mancini in RI.
They use PPG paint at the shop
Got me a NEW Project
1970 GTX 440+6, 4 spd, 4.10 Dana and N96 FE5 (top/bottom) and black bucket interior.
Original transmission and Dana - Engine is a service replacement block.
Body has all stamped #s + VIN/TRIM tag and door sticker. Been hunting like all hell to find the Build Sheet.
garage find, only had 41,850 miles on ODO.
Re: Qustion on B5 blue [Re: Moparnut426] #2081825
05/28/16 01:25 PM
05/28/16 01:25 PM
Whats the number in 69? That is a good lookin Cuda and duster!
Re: Qustion on B5 blue [Re: Moparnut426] #2081828
05/28/16 01:34 PM
05/28/16 01:34 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
http://www.moparts.org/Tech/Archive/paint/1.html
The number under the chip is the Ditzler code for the color for a given year.
Re: Qustion on B5 blue [Re: Moparnut426] #2081829
05/28/16 01:38 PM
05/28/16 01:38 PM
Thanks you!!
Re: Qustion on B5 blue [Re: Moparnut426] #2081844
05/28/16 02:19 PM
05/28/16 02:19 PM
Az
69hemibeep Offline
69hemibeep  Offline
Az
PPG 2019 over gray sealer, cloudy day in Dana Point. Oops I meant marine layer not cloudy LOL
1969 Hemi Roadrunner 2nd owner
Re: Qustion on B5 blue [Re: 69hemibeep] #2082492
05/29/16 08:55 PM
05/29/16 08:55 PM
B.C.
mk_ Offline
mk_  Offline
B.C.
That looks very good, is that single stage paint or base/clear coat?
Re: Qustion on B5 blue [Re: Moparnut426] #2082831
05/30/16 02:11 PM
05/30/16 02:11 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
PPG all the way - single stage
Re: Qustion on B5 blue [Re: mk_] #2082904
05/30/16 04:44 PM
05/30/16 04:44 PM
Az
69hemibeep Offline
69hemibeep  Offline
Az
Base clear
