rying #2081538
05/27/16 10:16 PM
05/27/16 10:16 PM
MN
har Offline OP
har  Offline OP
MN
having a challenging time to figure this out .i have a 72 demon340 bought a painless wire harness,looking for all the pigtails connectors (headlights,side marker lights,stop/tail/turn,alt,headlamps,volt reg,dist,coil,ign cont unit,h/l dimmer switch) so i don't have to reuse old factory ones so i don't have to cut off original harness.where do i go to get these pigtails.thanx har
Re: rying [Re: har] #2081557
05/27/16 10:51 PM
05/27/16 10:51 PM
welcome aboard! www.classicindustries.com MAY have something & they are online. other than that I would Google it
Re: rying [Re: har] #2081564
05/27/16 10:55 PM
05/27/16 10:55 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
If the car is stock, using a correct reproduction wiring harness would probably be the better way to go then the painless one. Believe the ones sold by YearOne are the ones to go with.
Aside from that...to get all of the connectors through the car, butchering an old harness would probably be your route to take.
Re: rying [Re: har] #2081681
05/28/16 04:06 AM
05/28/16 04:06 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
