Challenger wiring experts ? #1992645
01/17/16 03:26 PM
01/17/16 03:26 PM
Jacksonville Fl
70BigBlockSE Offline OP
Jacksonville Fl
car is a 70 SE with Rallye dash. It's been 7 years since I took it apart and of course I didn't properly document what was connected where. I've been looking in the FSM and so far have struck out. First wire in question is just forward of the passenger door, 3 pin connector with 4 wires. 2 yellow with black trace, 1 red and 1 dark blue with white trace. Where does this go?
Re: Challenger wiring experts ? [Re: 70BigBlockSE] #1992654
01/17/16 03:39 PM
01/17/16 03:39 PM
Pittsburgh, PA
Slotts Offline
Slotts  Offline
Pittsburgh, PA
That socket connects to a 2983872 key in ignition buzzer relay. It bolts to the bottom dash frame and right beside it should be a 2983336 low full relay for the SE/GC e bodies.
Re: Challenger wiring experts ? [Re: Slotts] #1992703
01/17/16 04:16 PM
01/17/16 04:16 PM
Jacksonville Fl
Jacksonville Fl
many thanks! Now the second one. 2 wire connector with yellow and dark blue with white trace. Lamp is fed by a yellow wire.
Re: Challenger wiring experts ? [Re: 70BigBlockSE] #1992719
01/17/16 04:36 PM
01/17/16 04:36 PM
Pittsburgh, PA
Slotts Offline
Slotts  Offline
Pittsburgh, PA
No problem at all. This second picture seems to be showing two different unrelated parts. The bulb fixture is called a title light that works from your delay lighting sub harness. That mounts on your gauge cluster light bar on the far left to light the switch panel. The five sided connector is part of the low fuel relay wiring.
Re: Challenger wiring experts ? [Re: Slotts] #1992760
01/17/16 05:16 PM
01/17/16 05:16 PM
Jacksonville Fl
Jacksonville Fl
and this is the low fuel relay, right?
Re: Challenger wiring experts ? [Re: 70BigBlockSE] #1992771
01/17/16 05:30 PM
01/17/16 05:30 PM
Pittsburgh, PA
Slotts Offline
Slotts  Offline
Pittsburgh, PA
That's correct.
Re: Challenger wiring experts ? [Re: Slotts] #2080869
05/26/16 07:35 PM
05/26/16 07:35 PM
Jacksonville Fl
Jacksonville Fl
one more wiring question. Solid dark blue wire behind gauge cluster. It's not my fuel gauge becuase I just found that and fixed it last night. My tach works so it's not that. Any other dark blue with no trace back there?
Re: Challenger wiring experts ? [Re: 70BigBlockSE] #2080876
05/26/16 07:50 PM
05/26/16 07:50 PM
Florida, US
72ls5fla Offline
72ls5fla  Offline
Florida, US
I'm not an expert but if that blue wire is on one of the posts for the ammeter gauge I believe it should not be there.
It's either is for the fuel, temp or oil gauges
Pretty sure on this.
I'm sure an expert will chime in.
Bill
Got me a NEW Project
1970 GTX 440+6, 4 spd, 4.10 Dana and N96 FE5 (top/bottom) and black bucket interior.
Original transmission and Dana - Engine is a service replacement block.
Body has all stamped #s + VIN/TRIM tag and door sticker. Been hunting like all hell to find the Build Sheet.
garage find, only had 41,850 miles on ODO.
Re: Challenger wiring experts ? [Re: 70BigBlockSE] #2081064
05/27/16 01:12 AM
05/27/16 01:12 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
If we all turn to page 8-94 of our FSM
The Dark blue with tracer & Black socket go to the Brake lamp.
The Blue wire either goes to the fuel gauge or the tach - it goes not go on the ammeter
Re: Challenger wiring experts ? [Re: 70BigBlockSE] #2081074
05/27/16 01:37 AM
05/27/16 01:37 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Blue is fuel
Purple is temp
Gray is oil
Just looked at a complete,dash out of the car, 1970
Then I thought for a second, same colors that go to the sending units.
What color wire is to your fuel gauge?
Re: Challenger wiring experts ? [Re: 70BigBlockSE] #2081265
05/27/16 01:31 PM
05/27/16 01:31 PM
Pittsburgh, PA
Slotts Offline
Slotts  Offline
Pittsburgh, PA
This is the tricky part with wiring on an SE - GC. The voltage limiter at the cluster powers a normal non rallye fuel and temperature gauges and the rallye cluster fuel, temperature and oil pressure gauges.
What is different with the SE - GC the fuel gauge does not use the voltage limiter for power, but with power from the low fuel relay. So, the normal dark blue wire from the fuel sender through the rear wiring harness connects to the DB terminal on the fuel gauge. Then there is a second identical dark blue wire from your low fuel relay mounted on the passenger side dash near the key-in buzzer relay that connects to the power input side of the fuel gauge.
The low fuel relay is a two circuit device driven both by heat. One circuit creating the pulsing voltage for powering the gauge and the second is the monitoring side of the fuel sending impedance to be able to light the low fuel bulb in the overhead console.
The picture of the internal circuit board shows these two contact points. The heat from the coil wrapped on the arm of the low fuel light contact would arc the arm away from it's resting point to keep from lighting the bulb between a full tank to just under a quarter tank. The heat from the coil wrapped on the arm of the pulsed voltage gauge contact would do just that. Warm and pull away, cool and make contact, on and off about every second.
I hope that clears up the SE - GC fuel wiring or is as clear as mud. whistling
Re: Challenger wiring experts ? [Re: Slotts] #2081735
05/28/16 10:22 AM
05/28/16 10:22 AM
Jacksonville Fl
Jacksonville Fl
Jim, that makes perfect sense! Thanks again
