Which Rear End Gears? #2080991
05/26/16 11:36 PM
05/26/16 11:36 PM
Martinsburg WV
mrm82 Offline OP
mrm82  Offline OP
Martinsburg WV
Aside from taking apart my rear end, how would I determine which rear end gears my 72 challenger has? I was under the assumption on my fender tag it would have a code D "72 thru 85" ? I have a D34 and then nothing until code E44. Any ideas? maybe I am just reading the codes wrong.... Thanks
Re: Which Rear End Gears? [Re: mrm82] #2080998
05/26/16 11:49 PM
05/26/16 11:49 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Likely 3.23's. Raise the rear and count the driveshaft rotation vs 1 rotation of the wheels.
Re: Which Rear End Gears? [Re: Pacnorthcuda] #2081009
05/27/16 12:03 AM
05/27/16 12:03 AM
blewbyu Offline
blewbyu  Offline
This only works if it is a sure grip, an open rear can not be counted by this method.
Re: Which Rear End Gears? [Re: mrm82] #2081036
05/27/16 12:46 AM
05/27/16 12:46 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Does the speedo read correct? If it does remove the gear and see how many teeth it has. What is your rear tire size. Do you have an aftermarket tachometer? What is your RPM at 60 MPH?
Re: Which Rear End Gears? [Re: mrm82] #2081051
05/27/16 12:57 AM
05/27/16 12:57 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Your rear end should have a little metal tag bolted to it that will have the ratio. Also the bottom of the carrier should be marked with wide stripes that also tell the ratio.
The gear ratio codes are not on the fender tag because they have nothing to do with how the body is built or painted.
Re: Which Rear End Gears? [Re: blewbyu] #2081052
05/27/16 12:59 AM
05/27/16 12:59 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I think it still works with an open if you leave one wheel on the ground
