Re: Which Rear End Gears?
[Re: Pacnorthcuda]
#2081009
05/27/16 12:03 AM
05/27/16 12:03 AM
Posts: 4,283 Florida
blewbyu
Likely 3.23's. Raise the rear and count the driveshaft rotation vs 1 rotation of the wheels. This only works if it is a sure grip, an open rear can not be counted by this method.
[Re: blewbyu]
#2081052
05/27/16 12:59 AM
05/27/16 12:59 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Likely 3.23's. Raise the rear and count the driveshaft rotation vs 1 rotation of the wheels. This only works if it is a sure grip, an open rear can not be counted by this method. I think it still works with an open if you leave one wheel on the ground
