Broken Drivers Door Window
#2073148
05/14/16 11:22 AM
05/14/16 11:22 AM
Posts: 674 Kennewick, Wa.
71vert340
Kennewick, Wa.
I was out in my shop the other day and looked at my 71 Challenger convertible. I walked around to the drivers door and the window had shattered and 95% of the glass was inside the bottom of the door. I had the car out a couple of weeks prior on a cool evening and had the window rolled down to the stops. I never put it up and my shop inside temperature got into the low 80s a couple of days. Shop stays locked and I was the only one in and out. Would expansion of the window in the warm temps cause this? I see AMD and a couple of other places sell the glass - any one better than the other or do they all sell the same repop glass? Hagerty is handling the claim and they're sending a check to cover it. I may end up installing the glass as no one here seems to want to do it. Thanks for any info. Terry
Re: Broken Drivers Door Window
[Re: 71vert340]
#2073167
05/14/16 11:48 AM
05/14/16 11:48 AM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
Tempered glass does weird things....
When you have the door panel off, check any metal edges that might me touching the glass ( in the windows entire up and down cycle) and make sure any area the edges of the glass set on or ride on do not touch metal.. Check for any rubber/fabric covered metal "guides" to make sure they have not worn down to metal, which is making "metal to glass contact"..
Remember that the weak point in tempered glass is the glass edge...
Use a shop vac to remove all the broken glass at the bottom of the door, but remember that some fasteners might have ended up in and with the broken glass. You might want to clean out your shop vac before using it and then go through it afterwards, making sure you don't lose any parts. The broken glass cannot scar you, but it is still sharp and can cut, so be careful....
[Re: 71vert340]
#2080478
05/26/16 02:55 AM
05/26/16 02:55 AM
71vert340
Kennewick, Wa.
Received my window from Auto City Classic Glass and it arrived packaged very well. I measured the thickness with a dial indicator and it's the same thickness as the original. Of course it's not PPG and date coded but all the holes are drilled correctly, it's not wavy and appears to be good quality and has the DOT marking. Just wanted to give an update. Terry
[Re: 1971 Gran Coupe]
#2080832
05/26/16 06:34 PM
05/26/16 06:34 PM
71vert340
Kennewick, Wa.
My glass is clear. I noticed when I retrieved the parts from the bottom of the door that there should be spacers (rubber) around the metal screws that pass through the holes in the glass. They had deteriorated and fallen apart. I've bought some plastic spacers and rubber spacers I'll install in the new glass to prevent the metal from contacting the glass. The window rail washers had also disappeared due to time. I'll install either the plastic spacers or rubber ones now. The glass is made by PMK out of Thailand and has a DOT516 number. Attached is a pic of the label on the glass. If I decide I want a PPG labeled window, I'll buy one and store it. Terry
[Re: 71vert340]
#2080992
05/26/16 11:38 PM
05/26/16 11:38 PM
minivan
Eugene, Oregon
Received my window from Auto City Classic Glass and it arrived packaged very well. I measured the thickness with a dial indicator and it's the same thickness as the original. Of course it's not PPG and date coded but all the holes are drilled correctly, it's not wavy and appears to be good quality and has the DOT marking. Just wanted to give an update. Terry Windshields are the usual culprits for being thinner today.. Your tempered doorglass was just a piece of glass that was heated,formed and then tempered.. A WS is two pieces of glass laminated together with a .060 interlayer.. I think the thinner WS's are due to most of the glass today is metric sized....
