Any EE1 Dark Blue '68 Darts out there??? #2079516
05/24/16 07:47 PM
05/24/16 07:47 PM
In The Hills
jughed Offline OP
jughed  Offline OP
In The Hills
Can't find any using the google image search. I understand that the color is not too common, but all i can find are B and C body cars, which makes me wonder if EE1 was even an option for A-bodies that year. Regardless, the Dart (originally Sunfire Yellow) is about to be painted and that's the color I'm going with. I would like to see what a Dart looks like in EE1.
Re: Any EE1 Dark Blue '68 Darts out there??? [Re: jughed] #2079543
05/24/16 08:36 PM
05/24/16 08:36 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I've seen a 68 Barracuda that color.
Re: Any EE1 Dark Blue '68 Darts out there??? [Re: jughed] #2079559
05/24/16 09:37 PM
05/24/16 09:37 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Originally Posted By jughed
... which makes me wonder if EE1 was an option for A-bodies that year.
It was
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: Any EE1 Dark Blue '68 Darts out there??? [Re: jughed] #2079617
05/24/16 11:02 PM
05/24/16 11:02 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
I saw a 67 dart in EE1. The color is dark blue but slightly different that the1968 EE1 color.
Re: Any EE1 Dark Blue '68 Darts out there??? [Re: autoxcuda] #2079640
05/24/16 11:37 PM
05/24/16 11:37 PM
In The Hills
jughed Offline OP
jughed  Offline OP
In The Hills
Thanks all for the replies...the fender tag answers the question.
Found this since last post. Sharp.
Re: Any EE1 Dark Blue '68 Darts out there??? [Re: jughed] #2079702
05/25/16 12:37 AM
05/25/16 12:37 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have a 68 Dart that was that color, but it has been in primer ever since I owned it. I will be interested in seeing one also! scope
JB Rhinehart, Realist
A-Body's RULE!
Re: Any EE1 Dark Blue '68 Darts out there??? [Re: jughed] #2079808
05/25/16 05:04 AM
05/25/16 05:04 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Re: Any EE1 Dark Blue '68 Darts out there??? [Re: autoxcuda] #2079837
05/25/16 08:44 AM
05/25/16 08:44 AM
In The Hills
jughed Offline OP
jughed  Offline OP
In The Hills
thanks for the pics, autoxcuda.
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: Any EE1 Dark Blue '68 Darts out there??? [Re: jughed] #2081341
05/27/16 04:05 PM
05/27/16 04:05 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
My Road Runner in EE1.
69 GTX 68 Road Runner
Re: Any EE1 Dark Blue '68 Darts out there??? [Re: jughed] #2107211
07/10/16 10:56 AM
07/10/16 10:56 AM
In The Hills
jughed Offline OP
jughed  Offline OP
In The Hills
Think i found one, too bad the ad does not mention the color code. No matter, EE1 is the color i'm going with. Now to find the paint code.
http://www.carsonline-ads.com/colsite/co...postingID=49263
Re: Any EE1 Dark Blue '68 Darts out there??? [Re: jughed] #2107313
07/10/16 02:41 PM
07/10/16 02:41 PM
central il.
second 70 Offline
second 70  Offline
central il.
Mike The PPG paint # for 1968 Dodge Dart EE1 Dark Blue Poly is 13372
Re: Any EE1 Dark Blue '68 Darts out there??? [Re: second 70] #2107605
07/10/16 11:59 PM
07/10/16 11:59 PM
In The Hills
jughed Offline OP
jughed  Offline OP
In The Hills
Thanks, MB!!!!
Hope to see your 'Cuda soon. Been a while.
Re: Any EE1 Dark Blue '68 Darts out there??? [Re: second 70] #2110913
07/16/16 12:19 AM
07/16/16 12:19 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Is that a base/clear code?
Re: Any EE1 Dark Blue '68 Darts out there??? [Re: JERICOGTX] #2113681
07/19/16 11:18 PM
07/19/16 11:18 PM
In The Hills
jughed Offline OP
jughed  Offline OP
In The Hills
Maybe he'll chime in soon.
more info on the color..
http://paintref.com/cgi-bin/paintdetail.cgi?ppg=13372
and more paint codes...
http://paintref.com/cgi-bin/colorcodedis...ame=Dark%20Blue
Re: Any EE1 Dark Blue '68 Darts out there??? [Re: JERICOGTX] #2114063
07/20/16 02:35 PM
07/20/16 02:35 PM
central il.
second 70 Offline
second 70  Offline
central il.
Jeff sorry it took so long to answer I didn't see the post. From what I've been told that once a number is given to a color it never changes and you should be able to have it mixed in any type of paint you want. So even if they call it the same color year to year the number can change and the color will be different.
I hope to see you guys again this year at drag week and maybe Joel can convince me my hemi was worth the extra money over a stroked 400. Lol
Re: Any EE1 Dark Blue '68 Darts out there??? [Re: jughed] #2115834
07/22/16 09:48 PM
07/22/16 09:48 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Joel and I will be at Drag Week again. He is going to bring his F.A.S.T. Legal '67 GTX this year. We installed CalTracs and mono leafs to utilize the require slicks for DW.
Thanks again for the EE1 info. Have been searching for years to find the correct code.
Re: Any EE1 Dark Blue '68 Darts out there??? [Re: JERICOGTX] #2868042
01/02/21 11:58 AM
01/02/21 11:58 AM
In The Hills
jughed Offline OP
jughed  Offline OP
In The Hills
Update...The car has been at painter's shop for almost a year. He did the final sanding and has started on the paint. Using the codes provided by the local paint shop, the color has turned out really good. Final judgement will be when it's viewed in sunlight. Can't wait to see it finished.
Re: Any EE1 Dark Blue '68 Darts out there??? [Re: jughed] #2868047
01/02/21 12:07 PM
01/02/21 12:07 PM
In The Hills
jughed Offline OP
jughed  Offline OP
In The Hills
....the color looks really close to that of the Charger mentioned in the original post
Re: Any EE1 Dark Blue '68 Darts out there??? [Re: jughed] #2868062
01/02/21 12:42 PM
01/02/21 12:42 PM
central il.
second 70 Offline
second 70  Offline
central il.
[quote=jughed]Update...The car has been at painter's shop for almost a year. He did the final sanding and has started on the paint. Using the codes provided by the local paint shop, the color has turned out really good. Final judgement will be when it's viewed in sunlight. Can't wait to see it finished.
Dang Mike Great news That's a Christmas miracle. Can't wait to see it done. Did Tommy paint it?
Re: Any EE1 Dark Blue '68 Darts out there??? [Re: jughed] #2868063
01/02/21 12:43 PM
01/02/21 12:43 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
E1 is one of my favorite Mopar colors; looks great on pretty much anything...
