Magnum 360 crankshaft same as LA 360? #207916
01/29/09 06:33 PM
01/29/09 06:33 PM
Thunder Bay,ON
LilRedDave Offline OP
Thunder Bay,ON
Like the subject says are the Magnum 360 crankshaft same as LA 360 cranks?
Re: Magnum 360 crankshaft same as LA 360? [Re: LilRedDave] #207917
01/29/09 06:42 PM
01/29/09 06:42 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I don't know if the crank is different, but the ballance weights on the converter are different?
I think they will interchange, but you may have to check the ballance?
Re: Magnum 360 crankshaft same as LA 360? [Re: 451Mopar] #207918
01/30/09 05:09 PM
01/30/09 05:09 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
I KNOW for a fact that the 318 La and Magnum cranks are one and the same; IDK about the 360s. but I do know that the external balance of a Mag vs an LA 360 is not the same. I had heard somewhere, the difference there is piston weight, could not tell you if thats the ONLY difference.
Re: Magnum 360 crankshaft same as LA 360? [Re: LilRedDave] #207919
01/30/09 08:25 PM
01/30/09 08:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The Hollander Interchange shows the 360 cranks interchanging '74 to '93 and '93 is a Magnum. Same top year for the 318.
Something changed in '94 for both.
Re: Magnum 360 crankshaft same as LA 360? [Re: volaredon] #207920
01/30/09 08:46 PM
01/30/09 08:46 PM
USA
K
krw71ragtop Offline
krw71ragtop  Offline
K
USA
The cranks can be interchanged but the balancer cant. You will find a lot of good info in the "How to Build Big-Inch Mopar small blocks" book (#SA104). Explains the differences between the LA and Magnum engines, and building the SB stroker motors.
Re: Magnum 360 crankshaft same as LA 360? [Re: krw71ragtop] #207921
01/30/09 08:53 PM
01/30/09 08:53 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
flexplate balance is different, too.
Re: Magnum 360 crankshaft same as LA 360? [Re: sharpie] #207922
01/30/09 08:58 PM
01/30/09 08:58 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Dumb question....but dont the Mags have a 1-piece RMS?
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Magnum 360 crankshaft same as LA 360? [Re: 69L78Nova] #207923
02/01/09 01:05 PM
02/01/09 01:05 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
NO they do not.
