Fan Shroud Repair #2078778
05/23/16 12:40 PM
05/23/16 12:40 PM
Missouri
3
3_RTs Offline OP
3_RTs  Offline OP
Missouri
I have a fan shroud that one part is cracked in two. Has anyone had any success with repairing one? Will ABS slurry work or is there a better solution, possibly plastic welding? Any success stories?
Thanks, Moparts!
Re: Fan Shroud Repair [Re: 3_RTs] #2078793
05/23/16 01:16 PM
05/23/16 01:16 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I cut down a 26" factory shroud to fit a 22" aluminum radiator and used Devcon Plastisteel epoxy. I cut it into four pieces and epoxied back together, people can't find where it was cut.
Re: Fan Shroud Repair [Re: justinp61] #2078998
05/23/16 08:03 PM
05/23/16 08:03 PM
IN
ahy Offline
ahy  Offline
IN
I have used a piece of aluminum sheet and small machine screws with self lock nuts. Also 2 part urethane and fiberglass cloth... basically plastic bumper repair stuff.
If you keep the repair inside the shroud and re-paint black with plastic paint, either repair can be very unobtrusive.
Re: Fan Shroud Repair [Re: 3_RTs] #2079022
05/23/16 09:09 PM
05/23/16 09:09 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: Fan Shroud Repair [Re: mopars4ever] #2079253
05/24/16 11:00 AM
05/24/16 11:00 AM
Missouri
3
3_RTs Offline OP
3_RTs  Offline OP
Missouri
Thanks everyone for good suggestions. I will research each and see which is the best for me.
