1972 Dart Swinger Special ?? #207884
01/29/09 06:06 PM
01/29/09 06:06 PM
duals Offline OP
duals  Offline OP
Can someone tell me what the difference between a Swinger and a Swinger Special is ?
Re: 1972 Dart Swinger Special ?? [Re: duals] #207885
01/29/09 07:01 PM
01/29/09 07:01 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Swinger special was the low line Dart for 71,72 and would have a LL as the vin.
Rubber floor mat, No rear arm rest bare bones. nothing "special" about them.
Re: 1972 Dart Swinger Special ?? [Re: duals] #207886
01/29/09 07:02 PM
01/29/09 07:02 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Here's a good place to start. It's the 72 Dodge data book and it lists the differences in the models.
72 Dodge Differences
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: 1972 Dart Swinger Special ?? [Re: duals] #207887
01/29/09 07:09 PM
01/29/09 07:09 PM
Cochise County Arizona
SPWC Offline
SPWC  Offline
Im not an expert,but I can tell you what I have researched since I own one myself.
Swinger Special is a base economy model of the 2 door Dart(Hence "Swinger").
From VALIANT.ORG -- http://www.valiant.org/dart/1972.html
DART SWINGER SPECIAL
"Dodge" on hood and deck lid
Pentastar fender medallion(according to HAMTRAMCK ARCHIVES,this is incorrect,No Pentastar was put on ANY A Body in 1972)
"Swinger" fender nameplate with separate "Special" plaque , "Dart" quarter panel nameplate
Bright windshield and backlight molding
6.95 x 14" black sidewall tires
198 slant-six or 318 V8
More Info From HAMTRAMCK ARCHIVES
http://www.hamtramck-historical.com/imag...t_Demon0006.jpg
http://www.hamtramck-historical.com/imag...t_Demon0007.jpg
(Click on either one to enlarge once you pull the page up)
Re: 1972 Dart Swinger Special ?? [Re: SPWC] #207888
01/29/09 08:33 PM
01/29/09 08:33 PM
duals Offline OP
duals  Offline OP
Thanks alot that pretty much describes the car I just bought but fender tag has an E24 for the engine which has hooker headers and full dual exhaust installed. I believe the E24 is a 225/6 ?
Re: 1972 Dart Swinger Special ?? [Re: duals] #207889
01/29/09 08:46 PM
01/29/09 08:46 PM
SPWC Offline
SPWC  Offline
E24 is a 225 /6 whereas E22 is a 198 /6
Re: 1972 Dart Swinger Special ?? [Re: SPWC] #207890
01/29/09 09:46 PM
01/29/09 09:46 PM
duals Offline OP
duals  Offline OP
So the 225/6 was an option on the Swinger Special in 72 ?
Re: 1972 Dart Swinger Special ?? [Re: duals] #207891
01/29/09 10:22 PM
01/29/09 10:22 PM
SPWC Offline
SPWC  Offline
Does the car have any badges or emblems on it?
On a true Swinger Special the DART emblem is on the quarter panel right behind the door.
The SWINGER emblem is on the front fender and underneath it will be a rectangular emblem which has the word "SPECIAL" on it.(SEE ATTACHED)
If im not mistaken a normal SWINGER has the "SWINGER" and "DART" Emblem on the front fender and nothing on the quarter
Re: 1972 Dart Swinger Special ?? [Re: SPWC] #207892
01/29/09 10:24 PM
01/29/09 10:24 PM
SPWC Offline
SPWC  Offline
The car you have may just be a "Swinger"
Here a pic of where the "Dart" Emblem is located on a "Swinger Special"
Re: 1972 Dart Swinger Special ?? [Re: SPWC] #207893
01/29/09 10:32 PM
01/29/09 10:32 PM
SPWC Offline
SPWC  Offline
Compare the pics of the emblems above to the emblems on this car and you will see a difference.
http://www.centralarkansasclassiccars.com/images/IMG_1348.JPG
Re: 1972 Dart Swinger Special ?? [Re: SPWC] #207894
01/30/09 11:43 AM
01/30/09 11:43 AM
duals Offline OP
duals  Offline OP
I have the broadcast sheet and it shows an LL code and it also shows the code 24 for the 225/6, front fender emblem is Swinger w/ Special under it, has Dart on the sides . This was a Canadian built car if this makes any difference, built for the USA.
Re: 1972 Dart Swinger Special ?? [Re: 69CoronetRT] #207895
01/30/09 06:40 PM
01/30/09 06:40 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
<a href="Hamtramck Historical: Dart model differences" target="_blank">http://www.hamtramck-historical.com/dealerships/1972DealershipDataBook-02.shtml</a>
Linky no worky
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: 1972 Dart Swinger Special ?? [Re: Rug_Trucker] #207896
01/30/09 06:54 PM
01/30/09 06:54 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Linky no worky
Thanks. I fixed it.
Seeking:
Re: 1972 Dart Swinger Special ?? [Re: duals] #207897
01/30/09 11:08 PM
01/30/09 11:08 PM
Clay Offline
Clay  Offline
Well I'm not a 1972 Swinger Special expert but I bought mine several years back from the original owner and it had the rubber floor mat with the "Swinger" "Special" emblems on the front fenders and the "Dart" emblems on the rear quarters. I was also told it had a radio delete when it was purchased new but a radio was added later by the previous owner. I have attached a picture of my car. I put the rally wheels on it because liked them better than the stock steel wheels and hubs.
Re: 1972 Dart Swinger Special ?? [Re: Clay] #207898
01/31/09 07:55 AM
01/31/09 07:55 AM
Rug_Trucker Offline
Rug_Trucker  Offline
My 72 Duster is a 198 3 speed on the column, no PS, PB, radio delete, rubber floor mat. It did have the black and white hounds tooth cloth.
Was that designated as anything?
Re: 1972 Dart Swinger Special ?? [Re: Rug_Trucker] #207899
01/31/09 08:42 AM
01/31/09 08:42 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Some little know info, In 71 and 72 Chrysler built a batch of 340 Swingers out of Swinger specials (LL Vin)
I have about 5 of these rare cars in my registry and will have some more info posted there soon.
Re: 1972 Dart Swinger Special ?? [Re: AdamR] #207900
01/31/09 10:48 PM
01/31/09 10:48 PM
stratford,ontario,canada
JD340 Offline
JD340  Offline
71+72? I've read about the 71 340 Swingers (75 or so built,right?) Never read about the 72's though. Interesting!
Nothing to see here. Carry on.
Re: 1972 Dart Swinger Special ?? [Re: JD340] #207901
02/01/09 09:18 AM
02/01/09 09:18 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Re: 1972 Dart Swinger Special ?? [Re: AdamR] #207902
02/05/09 02:56 PM
02/05/09 02:56 PM
Theres '70 340 swingers as well
Re: 1972 Dart Swinger Special ?? #207903
02/05/09 08:13 PM
02/05/09 08:13 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Those are well known though. There were over 13,000 built for US sales. The 71 and 72 were built in limited numbers for 2 dealerships in Canada only.
