Page 3 of 5 1 2 3 4 5
Re: lifter valley plate for trick flows [Re: Jimbo] #2078430
05/22/16 08:34 PM
05/22/16 08:34 PM
AndyF Offline
AndyF  Offline
The two piece design is adjustable. I can build a one piece design for my own engine but I wouldn't sell it as a product since I'd get an endless stream of complaints. People build engines with blocks that have been decked or with different head gaskets or with heads that have been milled but then blame me when the valley tray doesn't fit.
The two piece design has slots so it can slide back and forth to adjust for different deck heights, different head gasket thicknesses and different cylinder head heights.
Re: lifter valley plate for trick flows [Re: BradH] #2078469
05/22/16 09:57 PM
05/22/16 09:57 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Originally Posted By BradH
Originally Posted By TRENDZ
Why not one piece? make the ports standard size, and leave material around the ports for end user fitment.
Since you don't like his design, why not try building something yourself, instead of complaining about what Andy's coming up with on his own? You already described what you'd like to see made.
I have made what I describe. That's my whole point. It is very easy if you have the equipment. From the parts he's shown, its obvious that he could make one.
I was trying to stay out of the selling aspect, but if someone needs one made just pm me.
All I would need is a couple of simple measurements for anything that is not factory deck ht.
Re: lifter valley plate for trick flows [Re: TRENDZ] #2078514
05/22/16 11:17 PM
05/22/16 11:17 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Pics?
Re: lifter valley plate for trick flows [Re: Jimbo] #2078518
05/22/16 11:27 PM
05/22/16 11:27 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Hey Andy, I love your work and have used plenty of your tricks so I'm not being picky ok.
I made a ali valley tray for some 516 heads that I was using on the track years ago, the problem I had was the thin (1.2 mm about .050)tray broke it' seals on the front and rear of the engine because of vibration. I think your idea will need the flat bars each end and you will need to look at the join. Cheers Al
1963 Plymouth Max Wedge
1971 Barracuda
Re: lifter valley plate for trick flows [Re: AndyF] #2078688
05/23/16 09:08 AM
05/23/16 09:08 AM
moparx Offline
moparx  Offline
would there be a stiffening of the two piece if you incorporated a 90*flange approximately 3/8" into the lifter valley on the lower piece ? notching for the china walls of course. or would this be of little benefit ?
beer
Re: lifter valley plate for trick flows [Re: Jimbo] #2078691
05/23/16 09:20 AM
05/23/16 09:20 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I don't have pics of the part not on the engine. The engine had the intake ports moved up .750", so no off the shelf pan would work.
I'm not digging on Andy. His stuff is all top notch, and were I building another BB, he would be on speed dial. I just look for the simplest solution.
Re: lifter valley plate for trick flows [Re: moparx] #2078807
05/23/16 01:47 PM
05/23/16 01:47 PM
AndyF Offline
AndyF  Offline
beer
That actually seems like a good idea. By turning one edge down you would make the part stiffer.
Re: lifter valley plate for trick flows [Re: Jimbo] #2079690
05/25/16 12:23 AM
05/25/16 12:23 AM
AndyF Offline
AndyF  Offline
Here are some shots showing how I made the bat wings. First picture shows the blank and then the next picture shows the press brake tooling. A picture of the bent part and then a finished part after I glue the paper gaskets to each side.
DSC_9721 (Large).JPGDSC_9723 (Large).JPGDSC_9724 (Large).JPGDSC_9726 (Large).JPG
Re: lifter valley plate for trick flows [Re: AndyF] #2079768
05/25/16 02:00 AM
05/25/16 02:00 AM
SoCal
Brian Hafliger Offline
SoCal
How about one for me?? wave
Brian Hafliger
Re: lifter valley plate for trick flows [Re: Jimbo] #2079806
05/25/16 04:42 AM
05/25/16 04:42 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
didn't Hughes or someone have a 2 piece tray ? was a lot of complaints of leakage at overlap . that may be the hardest area to seal ?
maybe the folded edge will help this by being stiffer . maybe have a threaded bar spot welded to the plate rather than use sheet metal screws at least then they wont tear out
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: lifter valley plate for trick flows [Re: tex013] #2079854
05/25/16 09:39 AM
05/25/16 09:39 AM
moparx Offline
moparx  Offline
Tex
that's a good idea tex. maybe, with a "captured" bar instead of spot welding the aluminum. you could still put a stiffening bend in the middle, but have a couple of extra "tabs" down the length that could simply be folded over the bar, holding it in place. don't know what kind of equipment andy has to facilitate this arrangement though. sounds just like an engineer. take a simple idea and complicate it a bunch, then require extensive special equipment to manufacture. write up comprehensive, complicated instructions for installation and use, then set up exclusive marketing networks to distribute. biggrin
still a good idea though ! what ever andy decides, it will be a great product.
beer
Re: lifter valley plate for trick flows [Re: Jimbo] #2079865
05/25/16 10:05 AM
05/25/16 10:05 AM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
For my B1 heads, there was a gap to fill, when the block was heavy milled, so I made these bars from alum.sheet metal. My intake is O-ringded and easy to lift of to get access under.
Re: lifter valley plate for trick flows [Re: Brian Hafliger] #2079958
05/25/16 12:39 PM
05/25/16 12:39 PM
AndyF Offline
AndyF  Offline
You want a one piece design or a pair of the two piece? I can send you some prototype parts if you want. Some fitting may be required......
Re: lifter valley plate for trick flows [Re: AndyF] #2080285
05/25/16 10:01 PM
05/25/16 10:01 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Andy, when you get these sorted out and ready for sale please let me/us know, I was telling Doug my engine machinist about your idea and he thought the 2 piece would work well with the cast valley covers giving a shelf to seal with rtv and make a lot cleaner look. up
Re: lifter valley plate for trick flows [Re: Jimbo] #2081653
05/28/16 01:57 AM
05/28/16 01:57 AM
AndyF Offline
AndyF  Offline
I cut out a stiffener for the center of the valley. I'll probably just glue it to the plate and call it good.
Re: lifter valley plate for trick flows [Re: AndyF] #2081655
05/28/16 02:01 AM
05/28/16 02:01 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I like it.............
Re: lifter valley plate for trick flows [Re: AndyF] #2081690
05/28/16 05:01 AM
05/28/16 05:01 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Tex
New best MPH 130.32
Re: lifter valley plate for trick flows [Re: Jimbo] #2082012
05/28/16 09:21 PM
05/28/16 09:21 PM
Sidney Ohio
9SecRoadRunner Offline
Sidney Ohio
I didn't read all the posts so I'm not sure if this has been suggested, But what I did was get some sheet gasket material, cut out my own intake gaskets leaving an extra 3/8" on the bottom, then I scored it along that extra 3/8" and folded up making like an "L" shape along the bottom, it sat right on the indy plate ... a little sealer and it worked (so far).....
You Thinking It's So Doesn't Make It a Fact
Re: lifter valley plate for trick flows [Re: Jimbo] #2091310
06/13/16 05:46 PM
06/13/16 05:46 PM
AndyF Offline
AndyF  Offline
I ended up making some one piece valley plates as well as reinforcement plates for the center. I'll probably give this a try on the dyno.
Re: lifter valley plate for trick flows [Re: RT540] #2091316
06/13/16 06:01 PM
06/13/16 06:01 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
just an FYI, if that bung in the valley pan is a breather or vacuum pump it will blow oil out by the quart. Been there done that, it won't work.
Mopar to the bone!!!
