Torqueflite 727 non-repair question #2075895
05/18/16 03:28 PM
05/18/16 03:28 PM
Pasadena, Texas
fal3 Offline OP
fal3  Offline OP
Pasadena, Texas
Have a '67 b-body 440HP w/ 727. Nothing special, just got a good rebuild before installation (trans has about 7,000 miles on it). I like to upshift & downshift it manually; other times, it gets put in D and driven. Am I hurting the transmission shifting it manually? I seem to recall that back in the day it was ill-advised to shift it manually repeatedly-forgot why though. When I shift it manually, I start with the selector in 2nd, but once I get rolling (for street only), I put in first & upshift from there. I think I had read on Moparts it's a good thing to do to keep the sprag (right term?) from exploding.
Re: Torqueflite 727 non-repair question [Re: fal3] #2075906
05/18/16 03:46 PM
05/18/16 03:46 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Manual shifting doesn't hurt a thing. Starting off in first doesn't hurt anything either. It's doing burnouts in first that causes the sprag problems.
Re: Torqueflite 727 non-repair question [Re: fal3] #2075975
05/18/16 05:14 PM
05/18/16 05:14 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
In Drive, the rear band is not applied but in manual low the rear band is applied; on the 1-2 upshift the band has to release and the release is spring-only (Lotsa drag/overlap) this makes the band wear quicker since it was never intended to be applied/released on each shift cycle.
The sprag is in little danger in normal driving in Drive but when launching hard it's preferable to manually shift.
Re: Torqueflite 727 non-repair question [Re: fal3] #2076001
05/18/16 06:19 PM
05/18/16 06:19 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Downshifting into 1st(low) is not recommended while moving as that puts a shock load on the sprag, it can grab faster than the band will apply.
Re: Torqueflite 727 non-repair question [Re: John_Kunkel] #2076162
05/18/16 10:49 PM
05/18/16 10:49 PM
John are you sayin that manually shifting a "regular" TF is hard on the rear band no matter what (easy shifting/hard launch) & if launching hard it is still bad for it but when launching hard you DO want to manually shift as that is easier on the sprag? I had always read from decades ago that manually upshifting a regular TF was not recommended.
Re: Torqueflite 727 non-repair question [Re: RapidRobert] #2076500
05/19/16 02:23 PM
05/19/16 02:23 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
On a stock TF, the rear band applies in two stages, the spring-cushioned inner piston must compress before the larger main piston makes the final application. When released on the 1-2 upshift it also releases in two stages, this causes a delay in the release which equates to a lot of drag (wear) on the band and there is significant overlap because both the rear and kickdown bands are applied at the same time.
This is also true when launching hard in manual low but the safety of applying the band to protect the sprag outweighs the wear on the band.
Modified rear servos with billet pistons and heavier release springs mitigate the wear/overlap somewhat but it's still not advisable to manually shift on a regular basis.
Re: Torqueflite 727 non-repair question [Re: John_Kunkel] #2076679
05/19/16 07:23 PM
05/19/16 07:23 PM
John you are the man (as always!).
Re: Torqueflite 727 non-repair question [Re: RapidRobert] #2076718
05/19/16 08:11 PM
05/19/16 08:11 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
X2 beer
Re: Torqueflite 727 non-repair question [Re: John_Kunkel] #2076867
05/20/16 12:52 AM
05/20/16 12:52 AM
that confirms (to me) that me & John ain't even in the same city as far as knowledge goes. I can meticulously rebuild one & do a shift kit but that's about it
Re: Torqueflite 727 non-repair question [Re: fal3] #2077164
05/20/16 03:50 PM
05/20/16 03:50 PM
Pasadena, Texas
fal3 Offline OP
fal3  Offline OP
Pasadena, Texas
John-Kunkel; JohnRR; Rapid Robert: Thanks for the knowledge and responses! Looks like I'm cutting down on how much I manually shift the 727.
Re: Torqueflite 727 non-repair question [Re: fal3] #2077934
05/21/16 10:28 PM
05/21/16 10:28 PM
Minn
SportF Offline
SportF  Offline
Minn
Yes, don't shift your trans manually. Save it for the next guy. You might wear out the band and have fun at the same time and.....what the hell, isn't that why you have a fast car????? Drive it like you stole and fix it in the winter in 10 years. That is what winters are for. Holy mackerel, I just out driving my pushbutton Plymouth beating the stuffing out of the car and thinking, this is why I wait for nice weather. Don't manually shift it because the band is going to wear out!!!!!! Think about it, live, drive fast, life is short.
Re: Torqueflite 727 non-repair question [Re: SportF] #2078343
05/22/16 04:55 PM
05/22/16 04:55 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If you want to have fun shifting all the time, get a 4-speed.
Re: Torqueflite 727 non-repair question [Re: fal3] #2078349
05/22/16 05:01 PM
05/22/16 05:01 PM
P
Paul_Fancsali Offline
P
I can only say this I programmed my throttle pressure and shift kit to the point where the car is faster in the qtr in drive then manually shifting it
No more manually shifting for me it takes a lot of time but worth the effort. By the way stay away from man valve body's
Re: Torqueflite 727 non-repair question [Re: John_Kunkel] #2078462
05/22/16 09:45 PM
05/22/16 09:45 PM
Minn
SportF Offline
SportF  Offline
Minn
Life is short, play hard.
