1968 4 Speed Clutch Adjust Measurement Free Play #207790
01/29/09 03:48 PM
01/29/09 03:48 PM
fury4speed Offline OP
Where do you measure the clutch free play and how much should it be? thanks
Re: 1968 4 Speed Clutch Adjust Measurement Free Play [Re: fury4speed] #207791
01/29/09 03:55 PM
01/29/09 03:55 PM
pacific northwest
W
wings471 Offline
wings471  Offline
W
pacific northwest
Mine is 1 1/2" measured @ the pedal. Fresh clutch/p.plate & bearing.
Re: 1968 4 Speed Clutch Adjust Measurement Free Play [Re: fury4speed] #207792
01/29/09 07:07 PM
01/29/09 07:07 PM
Rio Linda, CA
John_Kunkel Offline
The Erection Connection
John_Kunkel  Offline
Rio Linda, CA
The factory recommends setting the distance between the throwout fork and its pushrod at 5/32". (I use a #21 drill bit as a gauge)
Re: 1968 4 Speed Clutch Adjust Measurement Free Play [Re: John_Kunkel] #207793
01/29/09 09:23 PM
01/29/09 09:23 PM
Thanks again for the info.
Re: 1968 4 Speed Clutch Adjust Measurement Free Play [Re: fury4speed] #207794
01/29/09 09:37 PM
01/29/09 09:37 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
My preference is to pull the inspection cover and adjust the throwout bearing slightly off of the pressure plate. Adjusting free play to a spec up above @ the pedal may have been acceptable in a new car with new linkage but not for a 40 year old muscle car that has worn linkage...
Just my $0.02..
Re: 1968 4 Speed Clutch Adjust Measurement Free Play [Re: John_Kunkel] #207795
01/29/09 10:56 PM
01/29/09 10:56 PM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
John, can you explain this procedure in a little more detail please?
Re: 1968 4 Speed Clutch Adjust Measurement Free Play [Re: SCATPK] #207796
01/30/09 03:46 PM
01/30/09 03:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
There is a nut and washer on the fork end of the pushrod, just turn the nut until you get 5/32" between that nut and the flat washer when pulling the fork to the rear against its spring.
Re: 1968 4 Speed Clutch Adjust Measurement Free Play [Re: John_Kunkel] #207797
01/30/09 05:40 PM
01/30/09 05:40 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Or the other correct way.From the old Direct Conection manual.
Re: 1968 4 Speed Clutch Adjust Measurement Free Play [Re: 62maxwgn] #207798
01/31/09 01:28 PM
01/31/09 01:28 PM
Thanks again for the info , I have my 5/32 drill ready to go.
Re: 1968 4 Speed Clutch Adjust Measurement Free Play [Re: fury4speed] #207799
02/02/09 10:05 PM
02/02/09 10:05 PM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
Thanks for the information fellas. John the 5/32 measurment at the washer worked like a charm!
Re: 1968 4 Speed Clutch Adjust Measurement Free Play [Re: SCATPK] #207800
02/02/09 10:50 PM
02/02/09 10:50 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
When adjusting clutch linkage 2 things are important.
The throwout bearing should be clear off the pressure plate fingers. Cover off and inspection is the best method here. Advice like 1" freeplay or 1 1/2" freeplay is just a huge saftey net for that adjustment. Major freeplay guarantees the bearing is clear but it's also wasted pedal throw which is important to quick shifting. Once the bearing is clear adding an inch to that just requires you to push in the pedal to disengage the disc. Tight is better. Alot of late model cars do not even run any clearance. Some are even preloaded against the fingers.
The other adjustment which is usually fine unless you have HUGE freeplay or some bad geometry in the linkage is disc clearance. The 0.060 62Max has shown is good. Anymore is just wasted clearance.
Re: 1968 4 Speed Clutch Adjust Measurement Free Play [Re: SCATPK] #207801
02/03/09 11:55 AM
02/03/09 11:55 AM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
.....and replace that cupped rubber washer w/ a metal one. Ehrenberg sells 'em on ebag
Re: 1968 4 Speed Clutch Adjust Measurement Free Play [Re: Kudakidd] #207802
02/03/09 12:08 PM
02/03/09 12:08 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And you can still get it from a dealer
Re: 1968 4 Speed Clutch Adjust Measurement Free Play [Re: 62maxwgn] #207803
02/03/09 02:20 PM
02/03/09 02:20 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
NE1 got a part # for the metal washer? the rubber ones last a few months.
Re: 1968 4 Speed Clutch Adjust Measurement Free Play [Re: ademon] #207804
02/03/09 02:45 PM
02/03/09 02:45 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
# 2401740
Re: 1968 4 Speed Clutch Adjust Measurement Free Play [Re: 62maxwgn] #207805
02/03/09 06:55 PM
02/03/09 06:55 PM
California
mickm Offline
mickm  Offline
California
the only ehrenberg i'm coming up with on ebay is a german guy. can you give me a link?
thanks...
Re: 1968 4 Speed Clutch Adjust Measurement Free Play [Re: mickm] #207806
03/09/09 10:52 AM
03/09/09 10:52 AM
Kudakidd Offline
Kudakidd  Offline
thanks...
Rick Ehrenberg
rick@richardehrenberg.com
Re: 1968 4 Speed Clutch Adjust Measurement Free Play [Re: Kudakidd] #207807
03/09/09 02:31 PM
03/09/09 02:31 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Unfortunately, I'm long since cleaned out of those NOS Moapr swivels. A Chevy rocker arm ball can work, just double-nut it.
By the way, with any clutch release bearing made in the last 20 years or so (high-precision /sealed), it is perfectly OK to set the free play at ZERO (or even a very small amount "negative"). (This comes stright from Chrysler engineering). This really improves clutch operation and feel, but you may want to make a pedal stop to prevent over-release. Alternately, I have moved the pedal up-stop down so the pedal is about 1" lower at rest, this is REALLY a nice upgrade.
Rick
Re: 1968 4 Speed Clutch Adjust Measurement Free Play [Re: 62maxwgn] #207808
03/11/09 07:40 AM
03/11/09 07:40 AM
Marlboro, NY, USA
Marlboro, NY, USA
]NE1 got a part # for the metal washer? the rubber ones last a few months.
# 2401740
... you got me all excited! But they have been NS1 for a decade, I just checked.
Rick
