NOT!!! How you want your race season to start off... (LONG)
#2077681
05/21/16 02:56 PM
05/21/16 02:56 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Part 1 - Finally got my '62 all back together this week. Started off last Sunday by having it ALMOST all together. Had the motor primed, and all I had to do was throw the distributor in it and button a few things up. Well tightening the boost line on the back of the manifold... the 9/32" socket falls off the ratchet, and OF COURSE... falls right into the distributor hole... all the way to the pan. @#$%^& So the next day I drain all the oil out, and I go fishing with a magnet through the drain plug hole... can't find it. Then after "fishing" for a while, I realize that the socket is probably sitting on top of the baffle... not in the sump. So I jack the back of the car up as high as I can get it... pound on the pan with a hammer, and I get it to roll down into the sump. Go "fishing" for a bit longer, and finally after 1hr plus of trying to get this thing out... I FINALLY get it hooked with the magnet! Only to find out.... it's about .020" too big to fit through the drain plug hole!!!! I don't know weather to laugh or cry at this point, but after all of that, the pan had to come off. VERY lucky for me my Dad (dvw) had just 1 week earlier convinced me to cut the K-frame JUST INCASE the pan ever had to come out in the car! So what's funny is I was able to get the pan off in 16 minutes after screwing around with the magnet for well over an hour! ha ha ha... Oh well... lesson learned. https://youtu.be/BN7NP3u8rSYGotta love racecars!
Re: NOT!!! How you want your race season to start off... (LONG)
[Re: dizuster]
#2077683
05/21/16 02:57 PM
05/21/16 02:57 PM
dizuster
Oakland, MI
Part 3 So Thursday night I'm back out in the garage again, taking the pan off AGAIN. Thanks again to dvw's wisdom to cut the K-frame... it all comes off pretty easy. But then I get the fun job of scraping all of the RTV off the block. Then I go to reinstall... remember that nice 1 piece magnum gasket? Well it works GREAT.... IF you are installing it on a stand. The front portion of the gasket goes over the pan like a normal small block piece, but the rear actually fits in a groove in the #5 cap. So if you put it on the block, it wants to fall off because of gravity... if you glue it to the pan first, then you can't get it in the cap. So I get my wife out to help, she does a great job, but I have to admit is NOT happy with the black RTV all over her hands... lol I said it'll wash off. She says, "I see the black stuff under your nails when you go to work every morning... it does not come off." LOL I got her a beer... tightened the pan up, and all was good.
[Re: dizuster]
#2077685
05/21/16 02:58 PM
05/21/16 02:58 PM
dizuster
Oakland, MI
Part 4 Took the day off for some runs at Milan, with thoughts of heading to Columbus right after for the mopar race this weekend at National Trail. Started off by taking the car for a ride, no oil leaks... all good. I go to get on the throttle to make sure the tuneup is close...and it won't make boost. 4-5psi and that's it. So I go back, I check the compressor, the regulator, all the lines, I have the laptop plugged in, check the MAP sensors for the boost controller... it's all doing everything it's supposed to. So then I determine the only way it could all be working and NOT make boost... is that it has to have a REALLY BIG boost leak. I start looking around and I find one of the clamps on the turbo is loose between the compressor housing and CHRA. AH HA! Must have forgotten to tighten the clamp! Easy fix... Except... it's not loose... it's broke. So I start calling around...Good luck finding a 8" V-band clamp in stock anywhere in Detroit! After calling 100 places, I finally gave up. Took it over to HardcoreB's house and he TIG'd it up for me. Good to go. Get home (now it's 2pm), slap the v-band back on, take the car for a ride...14psi... all good. Get home... load it up, and we head to Milan at 3:30.
[Re: dizuster]
#2077695
05/21/16 03:07 PM
05/21/16 03:07 PM
dizuster
Oakland, MI
Part 7 Work until 3am... get the head off and ultimately two pistons... OUCH... #7 piston [/URL] #7 Head #7 Head Closeup #3 piston #3 Head #3 Bore #3 bore Closeup NOT the way you want your engine to look on the night of your first race day!!!!!! #$%^&
[Re: dizuster]
#2077722
05/21/16 03:51 PM
05/21/16 03:51 PM
Posts: 20,172 Park Forest, IL
slantzilla
Park Forest, IL
Oh man, what a suckfest. Hopefully your luck gets better as the season goes on.
Watching your threads has me thinking I need to do a turbo in my Duster.
[Re: dizuster]
#2077735
05/21/16 04:30 PM
05/21/16 04:30 PM
Posts: 368 michigan
turbo toad
michigan
Dang i dont have to tell you but that fing stinks,stay at it thou you'll work thru it....
Check out my build on Facebook Ttoad Hurley its updated regularly
[Re: dizuster]
#2077771
05/21/16 06:00 PM
05/21/16 06:00 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thats a major... SUCKS... your car still doesnt hate you as much as mine did... at least mine is starting to come around.. sure hope you get it back together soon... what are you gonna do on that cyl wall.. is that bad enough to sleeve.. hard for me to tell in a pic.. best of luck with it Scott.... a lot of that will clean up with a tootsie roll
[Re: dizuster]
#2077777
05/21/16 06:14 PM
05/21/16 06:14 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Just think of the positive, at least you found the problem. I always have issues and cant find out why.....I am afraid something like that will happen to my hemi....Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#2077833
05/21/16 07:58 PM
05/21/16 07:58 PM
Posts: 12,385 Taxes & Virus's R-US, NY
Dragula
Totally feel your pain....That sucks....But your phone takes pretty good pictures.
[Re: Dragula]
#2077834
05/21/16 08:05 PM
05/21/16 08:05 PM
Posts: 20,164 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Scott sorry to see your issues with the new build. You are one of the most driven guys I know and that drive will get you past this hiccup and back to the track in no-time. Thoroughly check the pistons to make sure you don't have a pinched ring in all the effected cylinders. When my Son Matt broke a small piece of a valve off it pinched a ring on the other side of the block. Good-luck and great job of getting it apart and on its way back again so quickly.
[Re: dizuster]
#2077859
05/21/16 08:59 PM
05/21/16 08:59 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Check that turbine wheel... It looks like only half of that washer is there. It doesn't take much of a chunk of anything to damage the turbine wheel. You end up fixing the engine, then the turbo shakes itself apart, and goes back into the engine. Another reason to run an intercooler. Big parts "filter". Any clue of where the debris came from?
