Re: 904 Transmission kickdown lever shaft seal
[Re: 340clone]
#2077004
05/20/16 10:11 AM
05/20/16 10:11 AM
Posts: 75,066 U.S.S.A.
JohnRR
U.S.S.A.
There is a tool to pull and reinstall with doing nothing more than taking the linkage levers off, use a clamp with the driver tool to get it back on. You might have to unbolt the trans crossmember and lower the trans some to gain the needed clearance above.
[Re: 340clone]
#2077014
05/20/16 10:33 AM
05/20/16 10:33 AM
340clone
Thanks! This is good news! Do you know where I could get the tool? (What is it called?)
[Re: 340clone]
#2077203
05/20/16 05:10 PM
05/20/16 05:10 PM
Posts: 25,894 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I have a transmission leak at the kickdown lever shaft seal.
Kick down lever shaft seal or shift shaft seal?
[Re: John_Kunkel]
#2077217
05/20/16 05:44 PM
05/20/16 05:44 PM
340clone
Kick down lever shaft seal or shift shaft seal? Oops! Shift shaft seal. Just forward of the neutral safety switch. So is the fix the same, or does the valve body need to be removed?
[Re: 340clone]
#2077226
05/20/16 06:37 PM
05/20/16 06:37 PM
Posts: 15,551 Norwich CT USA
moparts
Norwich CT USA
you can change it with out the tool and in place
Small screw driver at an angle grab the seal and pop it out
Deep Socket to drive new seal in
All you need to do is remove the shift and kickdown leavers
Did my Challenger once and was working around the headers also
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
[Re: 340clone]
#2077228
05/20/16 06:44 PM
05/20/16 06:44 PM
Posts: 4,740 Florida
BDW
[Re: 340clone]
#2078376
05/22/16 06:11 PM
05/22/16 06:11 PM
John_Kunkel
Rio Linda, CA
So where does the kickdown seal go and how is it installed?
If it's not visibly leaking (likely) it's best to leave it alone. Once the e-clip and washer are removed to access the seal, it's possible to drop the shaft into the trans, even on the bench.
[Re: John_Kunkel]
#2078484
05/22/16 10:43 PM
05/22/16 10:43 PM
340clone
If it's not visibly leaking (likely) it's best to leave it alone. Once the e-clip and washer are removed to access the seal, it's possible to drop the shaft into the trans, even on the bench. It looks like it's leaking from only the shift shaft seal as far as I can tell. If there is a chance of dropping the shaft into the trans by attempting to change kickdown seal, than I shall take your advice and leave it alone.
