1969 B BODY A/C WATER CONTROL VALVE??? #207701
01/29/09 02:04 PM
01/29/09 02:04 PM
Anonymous OP
Anonymous OP
Does anyone have a picture of the placement of the factory A/C vacuum controlled water valve for 1969 B body cars?
Re: 1969 B BODY A/C WATER CONTROL VALVE??? #207702
01/29/09 05:35 PM
01/29/09 05:35 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
mine had A/C i think i have a pic of the firewall but without the valve.it is a square hole next to the blower mount[circle hole]
edit:" i am sorry you asked for the valve placement not the hookup on the fire wall.
from what i remember the vac hose was 1 ft long from the firewall.
here is a pic as it was connected.sorry it may not be clear enough!
edit:as i am remembering my valve was activated by cable just inside the firewall 1 unit where the hoses connect in the engine bay and the cable inside the car.the vacuum line went to the intake for the vacuum lines inside the car for the divertor door for the a/c heat.i feel dumb after posting all this.maybe you hade a vacuum activated system.
Re: 1969 B BODY A/C WATER CONTROL VALVE??? [Re: blownzoom440] #207703
01/29/09 09:26 PM
01/29/09 09:26 PM
Anonymous OP
Anonymous OP
Thanks for the above attempt but I don't see the vater valve I am talking about.
Anyone else?
Re: 1969 B BODY A/C WATER CONTROL VALVE??? #207704
01/29/09 11:24 PM
01/29/09 11:24 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
the valve isn't vacuum controlled on a 1969 ( or older for that matter) Thats a 1970 thing
But, ck out http://cgi.ebay.com/ebaymotors/1968-Dodg...1QQcmdZViewItem
Re: 1969 B BODY A/C WATER CONTROL VALVE??? [Re: gtx6970] #207705
01/30/09 12:14 AM
01/30/09 12:14 AM
Anonymous OP
Anonymous OP
EDIT
Actually what I have is the only thing available new for a 1969 B body for this application. The true application is shown in the link.
I need to know where to mount it and if it will in fact work for a 1969 b body application and how to hook it up.
Search for part number MP-WV101
http://megapartsusa.com/search.asp
Re: 1969 B BODY A/C WATER CONTROL VALVE??? #207706
01/30/09 02:28 PM
01/30/09 02:28 PM
Anonymous OP
Anonymous OP
Re: 1969 B BODY A/C WATER CONTROL VALVE??? #207707
01/31/09 06:29 PM
01/31/09 06:29 PM
Anonymous OP
Anonymous OP
Anyone??
Re: 1969 B BODY A/C WATER CONTROL VALVE??? #207708
01/31/09 06:44 PM
01/31/09 06:44 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
I have a 69 gtx with air that is not the one i have.I think it may be for a e body 1970 and up not sure.But it is not for a 69 b body with air
Re: 1969 B BODY A/C WATER CONTROL VALVE??? [Re: gtx69] #207709
01/31/09 06:55 PM
01/31/09 06:55 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
technically, it's a c-body part
Re: 1969 B BODY A/C WATER CONTROL VALVE??? #207710
01/31/09 07:33 PM
01/31/09 07:33 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
Go back to the link and read it again. It says "A/C Water Valve 1969-73 C-Body and 1971 B-Body". That's 71 B body only.
Re: 1969 B BODY A/C WATER CONTROL VALVE??? [Re: twodoorpost] #207711
01/31/09 07:57 PM
01/31/09 07:57 PM
Anonymous OP
Anonymous OP
Yes, I understand that. It is the only thing that is available for USE on a 1969 B body and would like to know WHERE it is supposed to be mounted on say a 71 B body.
Re: 1969 B BODY A/C WATER CONTROL VALVE??? #207712
01/31/09 08:07 PM
01/31/09 08:07 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Go here for heater valves www.vapinc.com then click on mopart parts then find heater valves
Re: 1969 B BODY A/C WATER CONTROL VALVE??? #207713
01/31/09 08:15 PM
01/31/09 08:15 PM
GMP440 Offline
GMP440  Offline
On the 71 and up B-Body cars, that valve that you gave the part number on is mounted on the right side of the engine compartment. Close to the firewall. I beleive it sits on a bracket.
However, that is not the valve assembly for a 69'
"B" body. The correct 70' and older heater/water valves are available either pricey NOS or there is a company rebuilds that valves. If you have one you can send it in and they will rebuild yours. I don't know the name of the company but if you google Dodge heater valve you should be able to find the company or maybe someone reading this thread may know.
Re: 1969 B BODY A/C WATER CONTROL VALVE??? [Re: gtx69] #207714
01/31/09 08:21 PM
01/31/09 08:21 PM
Anonymous OP
Anonymous OP
Thanks. They show that as a MANUAL valve for a 69-71 but doesn't appear to have any visible means of controling it manually such as a place to mount a cable.
Do you have one of these valves? Does it ressemble the original 69 OEM piece, as I don't recall what they look like or where they mount.
Re: 1969 B BODY A/C WATER CONTROL VALVE??? #207715
01/31/09 08:50 PM
01/31/09 08:50 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Mine looks like H1279
Re: 1969 B BODY A/C WATER CONTROL VALVE??? #207716
01/31/09 09:00 PM
01/31/09 09:00 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
1968 + 69 are cable controlled 1966-67 is also cable controlled but the cable works in the exact opposite of the 68-69 valve
Re: 1969 B BODY A/C WATER CONTROL VALVE??? [Re: gtx69] #207717
01/31/09 09:09 PM
01/31/09 09:09 PM
Anonymous OP
Anonymous OP
Is yours cable controlled and do you have a picture of it installed?
Re: 1969 B BODY A/C WATER CONTROL VALVE??? #207718
01/31/09 10:01 PM
01/31/09 10:01 PM
GMP440 Offline
GMP440  Offline
Here are pics of the correct valve. It is manually operated, not vacuum like that on the 1970 version of the valve.
Can you pst a pic of your engine compartment showing the right side fire wall assembly?
Re: 1969 B BODY A/C WATER CONTROL VALVE??? [Re: GMP440] #207719
01/31/09 10:03 PM
01/31/09 10:03 PM
GMP440 Offline
GMP440  Offline
Here is the 2nd pic showing the actual water valve assembly. These valves are a Ranco brand.
Re: 1969 B BODY A/C WATER CONTROL VALVE??? [Re: GMP440] #207720
01/31/09 10:06 PM
01/31/09 10:06 PM
GMP440 Offline
GMP440  Offline
These valves are operated by a cable coming from the far left push/pull switch on the A/C control panel assembly.
