CALLING ALL MOPAR 340 RESTO SIAMESE BLOCK OWNERS #2074353
05/16/16 04:42 AM
05/16/16 04:42 AM
Queensland Australia
moparmacka Offline OP
Is it absolutely necessary to drill the extra holes on the deck face so they intersect and match the holes in the head gasket and head face, on a "Mopar 340 Resto Siamese block". I have read the cooling section of 'How to build big inch Mopar small blocks' and Jim suggests you should drill 2 holes between the cylinders front and rear (yielding 6 holes each side total) at 55 degrees so that they intersect to allow water flow. And then restrict the big holes front and rear at the deck face by screwing a plug in with a 0.125 hole drilled in the plug. Just wondering for a street / strip engine with 600ish HP, if this is worth it or necessary. 400 Chevs are Siamese and don't seem to have over heating issues.
Macka
Re: CALLING ALL MOPAR 340 RESTO SIAMESE BLOCK OWNERS [Re: moparmacka] #2074376
05/16/16 08:49 AM
05/16/16 08:49 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
See where this thread goes but check with Ryan J at Shady Dell
Re: CALLING ALL MOPAR 340 RESTO SIAMESE BLOCK OWNERS [Re: moparmacka] #2074384
05/16/16 09:32 AM
05/16/16 09:32 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
400 chevys have the holes. There is no way to bleed the air from the lower "hour glass pinch" point without those holes.
Re: CALLING ALL MOPAR 340 RESTO SIAMESE BLOCK OWNERS [Re: moparmacka] #2074423
05/16/16 11:41 AM
05/16/16 11:41 AM
Indianapolis In. usa
Quickrunner Offline
Quickrunner  Offline
I ran a 340 resto block years ago on my W2 422 build and it did not have the holes and never had a cooling issue.
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: CALLING ALL MOPAR 340 RESTO SIAMESE BLOCK OWNERS [Re: Quickrunner] #2075973
05/18/16 05:11 PM
05/18/16 05:11 PM
I have heard that too. Just assemble it and run it maybe.
Re: CALLING ALL MOPAR 340 RESTO SIAMESE BLOCK OWNERS [Re: moparmacka] #2075993
05/18/16 05:54 PM
05/18/16 05:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The 400s use to have a issue of cranking heads due to
them getting hot because of the lack of the steam holes..
I changed many of those heads on a company that I use to
do maintenance on their trucks.. they were the early 400s
wave
Re: CALLING ALL MOPAR 340 RESTO SIAMESE BLOCK OWNERS [Re: moparmacka] #2076985
05/20/16 09:10 AM
05/20/16 09:10 AM
Woodbury, CT.
mcduff Offline
mcduff  Offline
Woodbury, CT.
I had the same concerns. Ryan J told me not neccessary. Been running 4 seasons now coming up on 300 passes and no issues running hot at all!. Race only no Street Time.
4.185 Bore.
Brett Miller 447 W9
