04 ctd #2075431
05/17/16 11:20 PM
05/17/16 11:20 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
would a bad oil pressure sensor cause an intermittent no start senario.
Re: 04 ctd [Re: bonefish] #2075458
05/18/16 12:00 AM
05/18/16 12:00 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
No. Does it only not start after sitting for a few hours or more? If so it is likely an injector issue.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 04 ctd [Re: 71yelladustr] #2075474
05/18/16 12:16 AM
05/18/16 12:16 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
no it runs great but every now and then it just wont start.if i let it sit a few hours it fires right up and runs great for a month or so then one day it wont start.it only does this after ive driven it,not like in the morning or if i dont drive it for a day.it always starts and runs on first start up.
Re: 04 ctd [Re: bonefish] #2076324
05/19/16 04:38 AM
05/19/16 04:38 AM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
Any codes?
Re: 04 ctd [Re: Tom_440] #2076361
05/19/16 10:05 AM
05/19/16 10:05 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
no codes,had 2 diff.shops run a complete scan.shows nothing.but by the time i can get it to them(thank goodness for AAA) it fires rite up and purrs like a gorella.
Re: 04 ctd [Re: bonefish] #2076477
05/19/16 01:45 PM
05/19/16 01:45 PM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
Did they test the injector return flow? If its too high at any injector it won't build rail pressure enough to fire the motor. There are some troubleshooting tips here under the heading
ENGINE WILL NOT START/HARD TO START
http://dodgeram.info/tsb/2006/14-003-06.htm
Re: 04 ctd [Re: Tom_440] #2076515
05/19/16 02:55 PM
05/19/16 02:55 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
i dont know what they did.but for 400.00 bucks i would hope it was thurough.im going to re look at my bill and see if i can decypher it and ask them some quest.Thanks for the link,i am mind boggled by how complex things have become.
Re: 04 ctd [Re: bonefish] #2076565
05/19/16 04:29 PM
05/19/16 04:29 PM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
Post up what they say.
Often the problem is the injectors, but they are expensive so its worth taking some time to troubleshoot for other issues first.
Re: 04 ctd [Re: Tom_440] #2076586
05/19/16 04:56 PM
05/19/16 04:56 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
