shifter question. #2075817
05/18/16 02:05 PM
05/18/16 02:05 PM
New Brunswick, Canada
TrxR Offline OP
TrxR  Offline OP
Ok guys i was watching street outlaws the other night and have been noticing that alot of the shifter arent solidly mounted. Is there a reason for this. They seem to rock back and forth.
Re: shifter question. [Re: TrxR] #2075828
05/18/16 02:17 PM
05/18/16 02:17 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Was thinking the exact same thing............. shruggy
Re: shifter question. [Re: Thumperdart] #2075835
05/18/16 02:20 PM
05/18/16 02:20 PM
Cab_Burge Online work
Cab_Burge  Online Work
Maybe it is because of the air shifters there using confused Mine is mounted solid so who knows shruggy
Re: shifter question. [Re: TrxR] #2075836
05/18/16 02:21 PM
05/18/16 02:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its pinned on... so they can pull the tunnel easy..
I did the same thing... its a tube with a slide in tube
with a pin holding the tubes.. you can see the way I did it
wave
