1969 Chrysler battery cable number
#2075360
05/17/16 09:20 PM
05/17/16 09:20 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
It appears I need to replace my battery cables. M&H can fabricate a new cables for me but they're asking for part numbers. Does anybody have the numbers? Car was built March 18 1969, '69 300, standard engine code K, automatic, A/C, most all options if it makes a difference.
Negative cable measures 21 ~ 22 inches.
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
Re: 1969 Chrysler battery cable number
[Re: 3hundred]
#2075405
05/17/16 10:32 PM
05/17/16 10:32 PM
Posts: 2,921 Calgary, Alberta Canada
a12rag
Robert,
Howdy ! Not sure if this will help out, but the 1970 part number for the negative cable for "Chrysler" with 8 cylinder eng, is 2983778 (#4 gauge, 23" long). And the positive cable 2983636 or 2983499 don't know why there are two different numbers for it. Again these are from the 70 parts book, hopefully someone out there has the 69 parts book and could confirm for you . . . good luck !
Cheers,
Mark
[Re: a12rag]
#2075692
05/18/16 10:36 AM
05/18/16 10:36 AM
3hundred
Colleyville
Thanks Mark! According to: http://www.hiltopautoparts.com/product/n...-body-w-60-amp/ the first number is specific to 1970 and 1971 w/ 60 amp alternator. I'm think that ups the charge wire to 6 GA. from the normal 10 GA. ? Probably changes the connection as well. The only hit I got on the other number was Dan on Moparchat looking for it back in 2002 for his '70 SF GT. Any other input? Robert
[Re: 3hundred]
#2075785
05/18/16 01:31 PM
05/18/16 01:31 PM
3hundred
Colleyville
Found this, attached. I'm guessing the up to May 1968 means May 1969?
Suspect 2926797 is the correct number, concur?
Thanks, Robert
[Re: 3hundred]
#2075867
05/18/16 02:55 PM
05/18/16 02:55 PM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
Try Atlas Obselete parts ij Columbus Ohio.They have lots of stock stuff.They did have good parts listings also.Rocky
Chrysler Firepower
